Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Unread 22-02-2004, 22:18
Umm Errr...
Re: need joysticks!
Problem easily solved. Go to your local comp USA/Best buy/Frys/Circuit city/Microcenter/Walmart etc and buy whatever joystick you want. ANY non-usb joystick will work.
1139 Alumni
Unread 22-02-2004, 22:45
Re: need joysticks!
That's not true. Many newer gameport joysticks do not follow the gameport standard. If the box says windows only (or doesn't mention dos) in the system requirements, then it probably won't work.
Another indication that it probably won't work is if it has more then 8 switches or more then 4 analog inputs. Another is that is has a "pass through" to allow you to connect multiple joysticks to it.
Unread 23-02-2004, 19:12
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: need joysticks!
I just want you to know that team 237 TRIBE will be delivering you a joystick sometime tommorrow. We asked the team tonight and they said they were willing to donate since we have several spares.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 23-02-2004, 19:42
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Re: need joysticks!
If you still end up needing joysticks team 521 would be glad to give up our surplus of joysticks, i belive i rember you guys had a small problem with them at the scrimmage, pm me if you still need them.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Other joysticks tml240 Programming 8 05-02-2004 15:09
number of joysticks doy Rules/Strategy 5 01-02-2004 00:05
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
