Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 22-02-2004, 09:55
DemonYawgmoth's Avatar
DemonYawgmoth DemonYawgmoth is offline
AKA: Artem Kochnev
FRC #1396 (Pyrobots)
DemonYawgmoth is an unknown quantity at this point
Send a message via AIM to DemonYawgmoth Send a message via MSN to DemonYawgmoth
Neutral for joysticks isn't 127
The neutral position for our joysticks is not 127, and this is making us mess up a bit. For the left side, neutral is 165, and for the right, neutral is 193. What could be causing this, and how do we make it go back to the original 127 position?
Unread 22-02-2004, 10:07
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Re: Neutral for joysticks isn't 127
I'm assuming since you're including numbers, the problem is the PWMs are neutral (solid yellow) when the values the RC outputs are 165 and 193, respectively - I'm assuming the problem isn't in the calibration of wheel of the joystick.
Sometimes the victors get a little-bit screwey and don't recognize the signal coming out of the RC correctly. There is a method to calibrate the actual victors. In page two of the IFI Victor 884 Users Manual, it has the instructions on what to do to calibrate the victor. After pressing a few things, you essentially move your joystick to full forward, full back, and the neutral position. The victor then detects what the signal coming out of the RC is at these positions and adjusts itself appropriately. Before you do this, though, I recommend you use the calibration wheel on the joystick to make sure when you move the joystick into neutral, the RC sees 127 as coming in.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 22-02-2004, 12:38
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
If the neutral position is not 127 you can trim them by adjusting the wheel next to each axis on the joystick. Turn the wheel until both give you the 127 value you are looking for. Then find some heavy duty tape and hold them down so they won't move again
Note: Not the thumb wheel which you can optionally use as an input. The adjustment wheels.
Unread 22-02-2004, 12:45
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
a small not, this year's joysticks do not have thumb wheels. instead, they have the hat switches on top, which are mapped to the pX_wheel axis.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 22-02-2004, 12:49
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
if you havnt edited the printf function in your code you can use that to esaly see what values your joysticks are. just move the trim wheel till it reads 127 ish. the output screen for printf function is the window that pops up after loading a program
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 22-02-2004, 19:32
AKA: Artem Kochnev
we do have the printf function showing us a number of things through hyperterminal, and thats where we got the readings of 165 and 193 from.
Unread 22-02-2004, 19:36
adjust your trim tabs on the joysticks - the little black thumbnobs on the white base of the unit.
Unread 22-02-2004, 19:37
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
i have found that this years joysticks really don't have that wonderful of a center position. we are using sticks from previous years.... other than the trim tabs being off you may need to do some scaling. what we do is this
#define left_MAX 254
#defing left_MIN 16
pwm01 = ((pwm01 - left_MIN) * 256) / (left_MAX-left_MIN);
this is the basic way we do it. i don't have the code with me but i know we break up the equation so we don't lose as much in the dividing so that the dividing is easier on the proc.
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 22-02-2004, 19:43
197 is not a sloppy center position problem - thats halfway to full power
and your code still wont help them if they dont adjust the trim tabs :^)
Unread 22-02-2004, 19:50
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
what you might wana try is to write a dead zone into code...
if(p1_x > 115 && p1_x <135) {p1_x = 127;}
just a thought.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 20:41
Crusty Mentor
FRC #0097
Yeah, sounds like its a calibration problem, not a programming fix - can you clarify what you mean by "neutral"? If those numbers are what your RC is outputting to make the victors solid yellow (neutral), then it definately sounds like your victors are just out of whack and need to be recalibrated.
Dan L
Team 97 Mentor
Unread 22-02-2004, 21:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Use the dashboard app from IFI. The OI still spits to dashboard even if you don't have the RC on. Make sure the jumper is on OI
Unread 22-02-2004, 21:29
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Calibrate the Victors using the Victor 884 calibration procedure. Basically you hold down the calibration button on the victor with an allen wrench or other small tool while you move the joystick from center to full forward to full backward and back to center. The Victor's LED should flash green once this procedure is complete.
Unread 22-02-2004, 21:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I cannot discourage you enough not to mess with the calibration of the Victors.
Use the factory cals. The other way lies madness!
I am serious. Rescale your joysticks in code if you have to but I think you will be very very sorry if you start messing with the cals on the Victors.
There are lots of good reasons not to recal the Victor, but one of the best is that if you ever blow a Victor and replace it you will have to recal, and probably right before the championship round, if Murphy's Law holds.
The non-centering joystick is easy to solve in software, stay away from the Cal button on your Victors...
Joe J.
Unread 22-02-2004, 23:20
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
I think the problem that they have though is that the 'center' is sooo far off that they are losing some resolution. If the center was at 135 instead of 127; it's not that big a deal. But, when they are talking 190 something being a neutral then the joystick becomes very sensitive; even with scaling.
What specific things have been observed with the recal of Victors that is negative?
Sean
variable? manodrum Programming 11 01-04-2003 17:20
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
programming gear switing Amadkow Programming 5 16-02-2002 18:07
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
