Go to Post FRANK, YOU'RE THE MAN. - Libby K [more]
Unread 23-02-2004, 07:23
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Big Question concerning Interrupt Pins 3-6
Happy Monday to all!
I had a revelation while sitting in the shower....
We have two mechanical encoders on our bot. They have four output pins each. One is a ground, one is for the voltage or whatever, and the other two are signals. The two signals are offset by either 1/2 or 1/4 of a sine wave. At andy rate, they don't change at the exact same time.
So I was thinking.... Is there a way that I could combine the two signal wires into one and stick each encoder on one of the digital interrrupts (3-6) because they can detect a change in state? If I could it would make coding much much easier and it'd be sweeeeeeeeeet. I just don't know enough about the electric signal coming out of the encoder to be able to judge.
Thanks alot.
By the way.... Did anyone else wake up this morning and hope that Monday wasn't here ALREADY!!!!
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 23-02-2004, 08:22
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Big Question concerning Interrupt Pins 3-6
The reason it has 2, is because it has 2 sensors on it. they are set half a notch apart from one another. The theary behind it is that you get directional ability by seeing the order the things hit. If you dont need direction you could just use one of the signal wires. If you want high res and all the features of the encoder (do you want to know if its going forword or backword) you could just put the second signal wire on its own interupt (excluding the power/ground).
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 23-02-2004, 08:40
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Kevin Watson posted an encoder example on his web site kevin.org/frc. The output of the encoder is called Gray Code and is set up so that only one channel changes at a time. Channel A leads channel B by 90 degrees. Thats just a fancy way of saying that channel B won't see a state change until halfway through a state change on channel A. Here is the order the signals will change as the shaft rotates:
A   B
0   0
1   0
1   1
0   1
0   0
Looking at Channel A, there are two rising edges (transition from 0 to 1). In one direction, from top to bottom, Channel B is 0. In the other direction Channel B is 1. That means that an interrupt triggered on the rising edge of Channel A will give you both distance and direction. You will connect Channel A to an interrupt set up to look for a rising edge and Channel B to a digital input. Inside the ISR, if Channel B is high you're moving in one direction and if its low you're moving in the other.
Unread 23-02-2004, 08:52
Linux Guy
AKA: maxdamage
Kevin Watsons example only shows how to set up the interupts. It is alot more involved than that. You must be very acurate with your messurements of wheel diameter or your distance/speed readings will be way off. You also need to know how many times the state will change per turn.
Unread 23-02-2004, 13:02
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Forgive me for possibly asking a dumb question but aren't you making this way harder than it needs to be? We've just got an aluminum disk with 30 holes punched in it and the encoder that first gives you. Our interrupt handler is a whopping shaft_encoder++;
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 23-02-2004, 13:57
Linux Guy
AKA: maxdamage
30? We got a laser cut piece of polystierene with 16 holes and it works fine. I guess what direction the bot is going by assuming that power over 127 is forward and below 127 is reverse. Good for speed, bad for distance
Unread 23-02-2004, 14:32
None #0116
The wheels on our robot are 12" in diameter. It would be difficult to mount an encoder disk anywhere but on the output shaft, so 30 holes would give us a resolution of 1.25". Not too bad. The down side is that if we get pushed backwards we won't know it. It also takes time to punch 30 holes in a disk, mount the sensors and debug it. We bought a 128 count/rev optical encoder. It gives us a resolution of 3 tenths of an inch, plus direction for free. Its one extra line of code to check the other encoder channel to get the direction. For a tank-drive robot the math is fairly involved to convert the distance measurements to the actual position. We figured that if we're going to do it we should have the best resolution possible.
Unread 23-02-2004, 15:07
AKA: Bill Rosemurgy
I'm still struggling with how to figure direction.... Any help?
www.team857.com
Unread 23-02-2004, 15:14
None #0116
I'm assuming you have an ISR coded already. Connect the signal pin not connected to the interrupt and ground to the signal and ground pins on digital input number 8. Your ISR will look like this:
volatile signed int distance = 0;
void Int_1_Handler()
	//check the other encoder channel. you may have
	//to switch the comparison value to 1 depending on
	//the configuration.
	if (rc_dig_in08 == 0)
		distance++;
	else
		distance--;
Unread 24-02-2004, 16:06
AKA: Bill Rosemurgy
I think I know what you are getting at but could you clarify this?
www.team857.com
Unread 24-02-2004, 16:13
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
basically, take whichever sensors isn't hooked up to the interrupt pin, and connect that sensor to digital input 8 - you'll need to hook up SIG and GND, and depending on the sensor, possibly +5V too.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 16:56
Just a clarification of why you are using the signals this way. At least I hope this ends up clarifying things.
In a quadrature encoder you have two signals out of phase by 90 degrees from each other. That's why you have two signal lines. (The word quadrature means 90 degrees.)
When the primary signal line goes high it causes the interrupt (in this case in digital input 1). If you check the second signal line (in this case on digital input 8) at the same time you will see it will always be low when the wheels are rotating in one direction and always high when the wheels are rotating in the opposite direction. So you can add counts going forward and subtract from your count when going backwards.
Think of two square waves offset from each other like this:
____----____---- signal A
__----____----____ signal B
If you think of a vertical line moving from left to right you'll see whenever signal A goes high (---) signal B is always high too (---).
But moving your imaginary vertical line from right to left, whenever signal A goes high (---) signal B is always low (___).
[edit] I had to come back and finish up this explanation later, because my car pool was leaving.
Unread 24-02-2004, 21:43
AKA: Bill Rosemurgy
You're a genious....
I totally understand the concept. I'm just struggling as to how I hook it up.
What I tried today (and miserably failed at) is this:
I found a 4-cable pwm-like Y(splitter)-cable. On an interrupt pin (pin1) I stuck the ground to the ground, one of the two signals (The "A" signal) to the signal pin and the +5 to the +5. Then I stuck the split ground to the ground on digital6 and the split +5 to the split +5 and the other signal (the "B" signal) to the signal pin all on digital 6.
Is this correct?
I'm very/pretty sure of my code, as I have played around with interrupts a good deal and have a general knowledge of how they work and how to implement them...
www.team857.com
Unread 24-02-2004, 22:07
While you don't actually need the split +5v or ground on the digital input, only the signal pin is required, it shouldn't matter.
Is digital input 6 also setup as an interrupt? The code seanwitte posted assumes you are only polling. That's why he specified input 8 rather than one of the potential interrupts.
Unread 24-02-2004, 22:18
AKA: Bill Rosemurgy
sweet.
thanks for the quick reply.
While I know I don't have pin6 configured as an interrupt, I will try to move it anyways. Thanks for the info. Wiring will be much simpler now.
www.team857.com
Question about input pins. Tom Bottiglieri Programming 3 15-02-2004 15:12
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
BIG!!! Championship Location in Question Nate Smith Championship Event 194 05-11-2002 12:31
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
A Big Question?????? archiver 2001 7 23-06-2002 22:49
