Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 23-02-2004, 10:56
Shark[NH] Shark[NH] is offline
Shark[NH] is an unknown quantity at this point
Programming help
This is my first time programming the robot for our team. I was looking a tthe tracker code and cannot see how it works.
I can see that there are two sensors for each side. On the left side, you have a left and a right detector and on the right side, you have a left and a right detector. All I could find in the tracker code was one digital input defined. How do I connect up the 4 ir sensors and how do I code in the extra inputs to make this work?
I have been basing most everything off the default code... I still am not quite certain how to use the spike relays either...
Nick
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
