Go to Post An annoyed inspector is a thorough inspector! - Jon Stratis [more]
Unread 23-02-2004, 12:01
Lisa Huang Lisa Huang is offline
Lisa Huang is an unknown quantity at this point
Hot Motors
How can we prevent motors from overheating?
Unread 23-02-2004, 12:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hot Motors
heat sinks and/or fans. If the problem is really bad, you are geared to high and need a larger reduction.
Unread 23-02-2004, 12:05
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: Hot Motors
Muffin Fans mounted over the motors.
Use the 4 inch muffin fan over the pair of Drill motors works great.
Phil
Unread 23-02-2004, 12:07
JP_1163's Avatar
JP_1163 JP_1163 is offline
mentor
#1163 (Trojan Horses)
JP_1163 will become famous soon enoughJP_1163 will become famous soon enough
Re: Hot Motors
Our team also uses the muffin fans and that seems to help a tremendous amount. I'd like to discuss the idea of a heat sink with any team that uses them. Team 1163 is using the CIM motors and they are quite large. We're not sure how a heat sink could be built and how it could reduce heat while promoting designability and amterials usage.
Unread 23-02-2004, 12:08
Re: Hot Motors
Make sure that your motors are geared low enough that they don't come close to stalling.
Unread 23-02-2004, 13:04
Re: Hot Motors
one thing we have noticed about the drill motors and the supports FIRST supplied for them - the black plastic supports block a lot of air coming from the blower inside the motor.
We experimented with the parts from last year, cutting an angle into the flat sections of plastic, and the increase in airflow from the motors is VERY noticable.
We intend to mod the ones on this years robot if/when we have the motors out of the bot again.
Unread 23-02-2004, 13:19
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Re: Hot Motors
If the motors are REALLY overheating, nothing can save them Electrical motors don't like spinning slowly. We just melted a drill motor yesterday. Some advice - never allow a motor to sit there with some power applied to it This happened to us when the default robot code was uploaded into the RC and an uncalibrated joystick was left connected to the OI for aout 2 minutes. So, either recalibrate speed controllers or create a large "deadzone" in your code.
Unread 23-02-2004, 13:32
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Hot Motors
We have plenty of tem problems with Drill motors....and we simply blow the muffin fan over them and they are totally tamed!
Our CIM motors seem to have a much larger themal mass, and seem to overheat much slower. I suppose if we kept them running for extended periods, they would also turn into red-hot pokers eventually......but our batteries seem to die in about 10 minutes.....
-Quentin
Live free or die....
Unread 24-02-2004, 09:06
Srkasner Srkasner is offline
Srkasner is an unknown quantity at this point
Re: Hot Motors
For our drill motors, we made an intricate prototype cooling system (Though we're not using it because of weight issues):
We measure the motors to be 1 3/4 inches in diameter. When in the mount, 1 1/4 inches of motor was accessible. If you buy a copper pipe 1 3/4 in diameter, cut it in half so u get 2 semi-circle pieces of pipe. Then cut those pieces to be 1 1/4 inches long. Polish the inside and put some thermal compound on the inside. Then get a pipe 1 inch in diameter and solder the two end pieces you just made. Drill 2 1/2 inch holes 1 inch from the end of the pipe. Then drill a 1 inch hole in the middle and put a small muffin fan on the top so it’s sucking air out. This device becomes very cold and is a great way to cool off motors easily.
~Steve
Team 1124
There are only 10 types of people in this world; Those who understand binary, and those who do not.
Unread 07-03-2004, 13:11
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
Re: Hot Motors
~Steve
Team 1124
luckily enough, when disnging brackets for our CIMs and drills that are used on the drive train, we included a heat sink, however, some overheating occurs no matter what.
in the past we used a anti static circut coolant that goes about -60degrees F and -51degrees C. be careful, it is intended for industrial use only,and is the kind of stuff that gives you instant frostbite if applied to skin. as someone who has had cold hands on the team, trust me and keep this safe if you get it.
its called freez-it, and is made by chemtronics
hopefully this helps
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 07-03-2004, 13:34
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Hot Motors
Kast year all we did was make our own completely aluminum mounts for the drills. They were connected directly to the frame. They acted as a huge heatsinc on each motor and it was all we needed. Never over heated once. This year we us ethe CIM's and we also have them mounted in an aliuminum gearbox/mount. The aluminum only touchs the black part of the CIM's though. It does some good, but because it is not on the endplate where the wires come out, and all the heat goes, it can't absorb that much. We are going to go with it though. Through our practices we have only had two cool down a couple of times, after ten min. of continuos running. Good luck with the heat problem.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 07-03-2004, 17:40
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Re: Hot Motors
last year our team had that problem we just put springs around the motors and it worked so we did it just in case
Unread 07-03-2004, 18:43
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Hot Motors
If you do attach a heat sink to the motors it is also a good idea to put some heat sink compound between the motor and where it touches the heat sink. This will aid in transfering the heat from the motor to the heat sink. A small tube of heat sink compound is available at Radio Shack for under $5.
It's also possible that over time the cooling fans/fins in the motors will get dust and debris stuck to them decreasing air flow. This is also possible if you were doing any work on the robot (filing, grinding, ect.) near the motors that could cause debris to enter them. In this case you would want to blow the motors out with compressed air or one of those aerosol cans used for dusting electronics.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 07-03-2004, 18:51
Re: Hot Motors
Lisa,
You have a lot of good ideas here. The absolute best one is to make sure that the mechanical design is such that the motor is running in an efficient area of the motor curves. By designing your drive train to optimize power and speed you lower the electrical current and hence the heat caused by the excess electrical current. When the motors are run at these design speeds, the internal fan also is efficient enough to remove some of the excess heat. Adding external fans is the next best, but the tradeoffs are more weight and current demand. Heatsinks are also useful but only to the extent that they can effectively remove heat generated within the motor through conduction. In the case of the drill motor, the majority of heat is generated in the armature which is only connected to the case at the bearings and brushes. Fans can move air around the armature but heatsinks cannot.
I am not a big fan of the coolant spray idea used by some teams. The spray does produce a thermal shock on the metal parts of the motor and if you use enough, the metals change size (thermal contraction) and affect clearances inside the motor. The compounds used in the spray also tend to wash the lubricant out of the bearings. Finally, that nice white frost that occurs when you spray the motor is moisture from the air being frozen by the spray. As the frost melts that moisture may end up in your motor or other electronics where it can cause some real damage.
Unread 07-03-2004, 19:40
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Hot Motors
This topic has been flogged pretty thoroughly before in these fora (do a search for "motor overheat"), but seconding Joe and Al's recommendation - choose gear ratios that will let your motors run at efficient speeds. Remember that motors convert electrical energy into mechanical energy and heat.
To see how the drill motor speed is related to its efficiency, download the Skill Bosch with Gearbox Performance PDF from FIRST.
There are a number of excellent white papers (in the technical section) on motor and gear ratio selection.
Pete Kieselbach
How do people get hot motors? archiver 2001 11 23-06-2002 22:24
Are your motors HOT? Matt Reiland Motors 8 29-01-2002 22:24
