#16
Re: Major mechanical problems....
We dont necessaryilt think of it as being the motors themeselves because the bot runs fine off of the ground with either motor. We were just trying to problem solve with the CIMs and we thought that we were well ont he way, untilwe put the bot back on the ground.
#17
next chance you get, run the motors with the bot off the ground. if you can stop the wheel from turning with one hand, then it's not putting out enough torque
#18
We just tried that and we blew the fuse again. The whole things runs like mad until its put under stress. Based on the past posts, I think that we have a serious problem. We are going to dissasemble our gearboxes and check the driveshaft opening through the frame for any friction that may be occurring. If that doesnt solve the problem then we may drop the current drivedtrain altogether and create a direct drive system with sprockets and chains.
Thanks for the suggestions..any further ones please feel free to post, Thanks, Team 1380 |
#19
if you're blowing the fuses on the CIMs by stopping it with your hand, then it's not geared down enough, end of story. That isn't a problem with friction in your drivetrain. You have 2 options:
1. Change your drive train to gear the CIMs down more. You could accomplish this by putting the 10 tooth sprockets on the output of the gears, and the 45 tooth sprocket on the wheels, and then run the chain between them. 2. Go back to your drills and try to figure out what's wrong with them. |
#20
BEN |
#22
Motors draw a lot of current because they are put under a high load. By pushing the motor's beyond 40 amps just by putting more stress on the motors, it would appear that there is too much load in your drive system. You may have some parts which are not able to move as freely as they would like to. You also may have problems with parts of your drive train being misaligned. Any of these issues can cause the motors to draw too much current.
As for my suggestion in solving the problem: put the robot up on blocks and run the drive train. Stress it. Watch how the drive train reacts. See if anything doesn't align. See if anything hits anything else. That will help you diagnose the problem. Matt |
#23
We had a similar problem with our drill drive motors last year. The root cause turned out to be current draw. We discovered this when we borrowed a portable ammeter from our electrical lab at work. The solution was to simply lower our gear ratio. The down side was that we could no longer use the drills in high gear for a high speed.
#24
what Ben said! you assembled the transmission backwards - the small gear MUST be on the motor shaft and the large gear on the wheel shaft man! your wheels must be spinning a couple thousand RPMs when you have them off the floor! also, it would be better to get the original drill motors and white gearheads in there instead - they are geard down lower than the Chips - and the FIRST transmission was designed for them. If your motors were destroyed you can buy replacements, you can even buy complete Bosch drills at the hardware store and put them in tonight - it will cost you more, but dropdead date is only 3 days away. |
#25
are you guys running 2 cim's? and if you are are you running both motors through one fuse?, because that will definately cause them to blow under any load, the only other thing you could do is to de-sensitize the joystick signal with programming, but don't ask me how to do this, i don't do the programming for our bot.
#26
Weighing the bot
Hey all. Hope all is going well and your successes are many this week. I've got a question about wieghing the bot. We measured earlier and were close, and are weighing all parts as they go on, but we'd still like to weigh the whole thing at once. Who does this? What's your techinique and/or piece of technology that you use?
#27
The official weigh in is during the practice day of the competition, by the volunteer robot inspecters.
We do our preliminary weigh-ins with a calibrated scale that was surplused from our corporate sponser. The scale is an extremely accurate one formerly used in our space division. Last edited by Peter Matteson : 23-02-2004 at 15:20. |
#28
a good way to weigh your robot if you don't have access to a shipping scale is to take a bathroom scale and put 2 pieces of 2x4 on it then sit your robot on the 2x4 look at the weight and then subtract the amount of the 2x4.
also please let us know how the transmission problem went and if you need any immediate advise feel free to call me 410-963-6085 |
#29
Re: Weighing the bot
When I was on 992, we threw the robot in the back of a minivan and drove to the nearest FedEx office. They were more than happy to let us use their scale.
#30
If the gearbox is assembled correctly, as was suggested in previous posts, then start of by removing the motors and turning the wheels by hand to see if there is any binding through the gearbox. Tweak the gearbox until all binding goes away. If those are 12 inch wheels, they ought to be spinning only 2 or 3 revs per second. 3 revs per second is about 9 feet per second, just to give you a ballpark estimate of speed. If those wheels are turning faster than that, your gear ratio is too high.
Good luck. We've all been there at one time or another. Just don't panic and start blaming anyone. Just concentrate on diagnosing the problem one piece at a time. |
| Most computer problems... | Joel J | Chit-Chat | 6 | 27-11-2005 16:58 |
| If you're having MPLAB problems, LOOK HERE. | Jeremy_Mc | Programming | 0 | 20-01-2004 18:06 |
| Do you all have problems with.... | Munkaboo | Website Design/Showcase | 19 | 03-03-2003 19:51 |
| Joystick problems | archiver | 2001 | 3 | 24-06-2002 02:40 |
| Radio problems -- not | archiver | 2000 | 1 | 23-06-2002 22:23 |
