Go to Post I'm not worried about talking to the robot, but I am worried about when the robot starts talking back... - Moros [more]
Unread 23-02-2004, 15:29
Mark Reynolds's Avatar
Mark Reynolds Mark Reynolds is offline
#0329 (R.A.I.D.)
Team Role: Driver
Mark Reynolds is an unknown quantity at this point
Send a message via AIM to Mark Reynolds
Question Dementions Needed
Does anyone know the dementions of the top of the ball tee (hieght) where the infered beacon?
Please need an answer A.S.A.P.
Thank You
Unread 23-02-2004, 15:33
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Dementions Needed
37.5 inches
http://www2.usfirst.org/2004comp/200..._and_Guard.pdf
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 23-02-2004, 15:34
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Dimensions Needed
Thank You
It would help if you used Dimensions. I'm pretty sure you can find them http://www2.usfirst.org/2004comp/200...rral_Panel.pdf or http://www2.usfirst.org/2004comp/2004_BALL_TEE_Dimensional_LAYOUT.pdf .
Rob, the second drawing shows the IR to be 3' 8" or 44" .
Unread 23-02-2004, 15:48
Roboticsrob
hmm, the two drawings do appear to be conflicting with each other. I would trust the one I posted more since thats the updated ones they posted and its labeled the 2004 field elements.
Unread 23-02-2004, 16:07
AKA: Nelson Green
I don't know.. I thought it seemed easier to read in the second one. Your pdf made it hard to know if that was the to the pvc or to the IR. Anyway they would take it down if it was wrong. I think the 37" is to the pvc and not to the top of the IR.
Unread 23-02-2004, 23:34
#0329 (R.A.I.D.)
Team Role: Driver
Thanks Guys....sorry about the spelling did it fast need an answer for our practice feild.
Unread 23-02-2004, 23:42
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Thank You
The infrared LEDs are at a height of 44" (I think that's what you wanted).
-Kevin
Kevin Watson
http://kevin.org
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
The Grand FIRST team.. programmers and others needed randomperson Programming 0 31-05-2003 23:46
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
Battlecry 3 volunteers needed? Hymnson Off-Season Events 4 02-06-2002 12:38
Inventor 5.0 help needed Larry Barello Inventor 4 27-01-2002 10:54
