Go to Post Nothing like GLR for your inaugural stint as a coach, lemme tell ya. - Kevin Sevcik [more]
Unread 23-02-2004, 16:18
snowdragon's Avatar
snowdragon snowdragon is offline
AKA: Kyle Blizzard
FRC #0280 (TnT Robotics)
snowdragon is an unknown quantity at this point
Exclamation Brake mode on pwm's
Which pins make the pwm's go into brake mode? ab or bc
Unread 23-02-2004, 17:13
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Re: Brake mode on pwm's
I assume that by "the pwm's" you mean "the speed controllers". Anyway, there's a little jumper on the Victor 884 near the LED and the PWM connector. If it's currently in coast mode, pull the jumper off and reconnect it in the other position to switch it to brake mode.
Unread 23-02-2004, 17:24
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Or just leave the jumper pin completely off.
Just remember that at power off at the end of the match that motors might unwind....
ie Winch motor has brake and your off the floor. Stop the winch and it will hold.
The match ends and your winch motor starts to unwind due to the load on the cable.
Phil
Unread 23-02-2004, 19:04
TNT280Staff's Avatar
TNT280Staff TNT280Staff is offline
AKA: Joe Horth
None #0280 ("TnT")
TNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the roughTNT280Staff is a jewel in the rough
to clarify the question... is "A" "B" coast mode or is it "B" "C"?? we need to know which location to place the jumper, we understand the dynamics of coast versus brake, just need to know which 2 pins to place the jumper on to get to coast mode.
Unread 23-02-2004, 19:11
C is for Coasting
thats good enough for me!
:c)
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
