Re: Swerve/crab drive and tank turning
yea we have the same treads as u must have noticed. It creates a huge stress on the wheel. Also right now we are using the CIMS on diagonaly and Drills diagonaly too. will it matter if we use chips in the front and drill on the back or vice versa? SO basically you guys(111) lifted the back of your base and used the front to tank, am i right? do you think if we take off the tread and use a different form of belting like the black ones from mcmaster( not treads on them, just plain black plasticy not sure what material)
question for 258- did you guys use treads last year i cant seem to remember? |
Here's a picture of someone else's omni wheels: http://www.chiefdelphi.com/forums/sh...ght=omni+wheel |
Our swerve had the drills and CIMs like yours. We used the same tread that you have in that picture you linked to for the Silicon Valley Regional, and we didn't have any trouble with normal tank style driving. We changed to a different read that was more resistant to the wire mesh for Cal Games, but only for that reason. Our modules were geared to go about 10 feet per second on 6" diameter wheels. Our setup also had our two drill modules in the front of the robot, and our two CIM modules in the rear (although we had a mode where we could rotate all the modules 90 degrees, and then change the front of the robot to whataver direction they rotated towards). Not that that mattered much last year. Here are a couple links to some pictures of our modules... http://www.seadawgs.com/Pictures/2003/SM1.htm http://www.seadawgs.com/Pictures/2003/SM2.htm -Bill PS - I'm glad to see another CA team tackle swerve in such a challenging year to do so. I can't wait to see your robot in person ![]() |
thanks Bill, Dave and other wildstang members.
Bill, yea i think you guys are being able to do tank turns because you had thin wheels. We have wide wheels and the creats sooo much stress we tried to turn. I think its just the fact of too much traction. We have couple of ideas and were gonna try them. thanks for all your help. if other teams tried to tackle the same problem please do post. thanks -Akshay |
Our wheels are 1.625" wide, with the cross hatch tred. Combined with the fact that we are geared to go 14 feet a sec and actually go 12 ft/s ,meaning we have no torque. We just stall the modules when tanking.
What I am thinking to do is get a small pneumatic cylinder with a caster on the end of it to pop down, not necesarily clear the 2 wheels, but decrease their traction. This way, we can turn with only 2 wheels and just spin around on that caster. Thanks all on your input. |
| Major problems with tank tread drive | Lord Nerdlinger | Technical Discussion | 13 | 23-02-2004 21:15 |
| tank drive | Stormhammer | Programming | 11 | 29-01-2004 23:08 |
| what's your most important drive train advice? | Ken Leung | Technical Discussion | 42 | 07-01-2003 09:58 |
| Blowing fuses/tuning drive train | DougHogg | Motors | 10 | 23-06-2002 00:24 |
| Quad- 1/2 track drive system | Ben Mitchell | Technical Discussion | 24 | 30-01-2002 11:55 |
