Go to Post Leave it to CD to misconstrue a joke this badly. - connor.worley [more]
Unread 22-02-2004, 03:33
Elgin Clock's Avatar
FRC #0237 (Black Magic)
WARNING - Keep those compressors cool or you may be slimed!!!!
Yesterday, I guess our compressor got a little to hot and started causing condensation in the tubing.. oops! I guess when one of the team members went to unplug a tube, it sprayed "slime" all over them!!! iwwww....
Are you sure we aren't allowed to use two compressors on our robot??? lol j/k
Keep them cool!!!
Unread 22-02-2004, 03:42
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: WARNING - Keep those compressors cool or you may be slimed!!!!
yes. our air compressor has been getting so hot that it will start to shake baddly and so hot that you will burn yourself if you touch it. we have to unplug the fuse after a while.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 22-02-2004, 04:46
Team1425's Avatar
Team1425 Team1425 is offline
#1425 (Wilsonville Robotics)
Team1425 is an unknown quantity at this point
We had problems with ours stalling at 80 Psi or so if it was too overheated, it wouldnt work right until we had given it a half hour or so to cool.
Our solution was that we got a cheap heatsink for a computer and mounted it with zip ties to the top of the compressor (after scraping off the paint and using tons of thermalpaste).
Even without a fan on the heatsink we are yet to have overheating problems
Unread 22-02-2004, 07:32
water in the lines is not from the compressor being too hot - its from the air being compressed - it causes the moisture in the air to condense out
professional compressors usually have a water trap - a little device that captures the water in a small cup, esp if you are using them for spray painting.
Unread 22-02-2004, 16:55
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
er, you guys ARE using the safty cut off valves and safety bleed valves, right
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 17:00
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
I suspect that those of you who are having overheating problems with the compressor haven't installed the new version of the ifi_aliases.h file. The relayx_fwd and relayx_rev aliases are reversed in the original version of the code, and that makes it highly probable that you've been running the compressor backwards. If the compressor polarity is reversed, it will still compress air, but its internal cooling fan will not work properly. Make sure the light on the Spike supplying power to the compressor is green. If not, either swap the compressor wires or fix the programming using the new version of the header file from IFI.
Unread 23-02-2004, 16:09
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
I'm rather confused... ha ha ha, programming newbie...
Our Spike connected to the compressor is hooked up to realay port 8, and the code under ifi_aliases.h consists of:
#define relay8_fwd LATDbits.LATD7
#define relay8_rev LATJbits.LATJ0
All the other ports say LATEbits instead of J, and Would have progressed consecutively, so, I think the bottom line should say LATEbits.LATE8, but I'm not sure.
Our spike is now running on red, and it is shaking and as hot as the above have described. Should I change this bottom line to what I thought, or what should I change it to?
Thanks,
Charley.
Team 1350
Manchester 2003 Rookie All Stars
Unread 23-02-2004, 16:16
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
The compressor shouldn't get that hot unless you are constantly running it. The more you run your cylinders, the more the compressor needs to be on, but don't ever keep it running constantly for long periods of time.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 23-02-2004, 16:24
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Thanks,
Charley.
Your best bet is to use the latest ifi_aliases.h file dated 2-18-2004. The code that you supplied is wrong, and will in fact supply reverse polarity power to your compressor. Your relay will light red and your comprossor will be hot due to the internal cooling malfunctioning. This is the correct code (but do get the new file):
#define relay8_fwd      LATJbits.LATJ0
#define relay8_rev      LATDbits.LATD7
Unread 23-02-2004, 16:51
Carpe diem
For those unsure, you can obtain the ifi_aliases.h file from the Innovation FIRST website. They are the suppliers of our control system. Their website is at: http://www.innovationfirst.com . The ifi_aliases.h file can be found in the zip file containg the defualt code; that can be found here: http://www.innovationfirst.com/FIRST...2004-02-18.zip .
Unread 23-02-2004, 17:06
#0246 (Overclocked)
If the LED on the Spike is red, you're running whatever's connected to it in reverse. Installing the new IFI header file will fix the relay aliases, which will cause your compressor to run forwards. That will allow the compressor's built-in cooling fan to run, which should help protect it and those who work with it from thermal damage.
Unread 23-02-2004, 18:31
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
After reading this tread we realized we've been running our compressor backwords since we got our pnuematics going a few days ago. The compressor kept heating up and we thought it was because we're using a lot of pnuematics this year and it had to keep running. All we did was reverse the leads between the spike and the compressor and now it's staying cool even though it still runs a lot.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 23-02-2004, 23:41
Linux Guy
AKA: maxdamage
You realy dont have to wory about heat in a 2 minute round. If you have to, make a booster tank and use an old compressor (unless your a rookie team ). Then fill it as needed via a valve on both ends.
Unread 24-02-2004, 00:21
#0246 (Overclocked)
It reduces the usable life of the compressor. Machines don't tend to be particularly fond of excess heat, and I suspect the compressor is no exception. While you certainly could get away with just running the compressor backwards, repairing the code to fix the problem is simple enough that refusing to do so would demonstrate an unbelievable amount of apathy towards the functionality of your robot.
Unread 24-02-2004, 06:44
Linux Guy
AKA: maxdamage
Then I guess its a good thing we have ours right.
Two Compressors Jay H 237 Pneumatics 16 16-02-2004 20:55
Hot days and cool nights archiver 1999 19 23-06-2002 22:22
Compressor Warning & Solutions Mike McIntyre OCCRA 0 29-10-2001 21:30
How do i create those cool animations mnkysp6353 General Forum 4 29-09-2001 00:34
