Go to Post kids these days, with their fancy aluminum sprockets, don't know how good they have it. - AllenGregoryIV [more]
Unread 23-02-2004, 16:56
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Swerve/crab drive and tank turning
Originally Posted by activemx
SO basically you guys(111) lifted the back of your base and used the front to tank, am i right?
Actually we lifted the front of our base and used the back to turn, but yeah...
do you think if we take off the tread and use a different form of belting like the black ones from mcmaster( not treads on them, just plain black plasticy not sure what material)
I'm not a mechanical guy so I can't comment on specific tread types, but from a generic point of view there's simply too much traction. You need to reduce that somehow. Last year we decided to temporarily reduce our traction by lifting two wheels off the ground using a slippery piece of Delrin. Putting something with less friction on your wheels will help, but then you're sacrificing traction. You could also use what we call BUPODs (others seem to call Omni Wheels) in place of two of your wheels, but they're a little complicated to construct. The advantage is they have good traction in one direction but also slip easily from side to side, allowing for easy tank turning. Our 2001 robot had these and it drove quite nicely.
Here's a picture of someone else's omni wheels: http://www.chiefdelphi.com/forums/sh...ght=omni+wheel
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
tank drive Stormhammer Programming 11 29-01-2004 23:08
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
