Go to Post "If all else fails, use a bigger hammer" - Steve Florence - Logan Byers [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 23-02-2004, 20:42
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Odd Escape
You are being held prisoner in a small room. Only you and a gaurd are inside the room. There are three identical doors that lead out of the room. The gaurd offers a choice: you may exit through one of the three doors. Two lead to your execution, one leads to escape. You have no knowledge of the doors and so you choose randomly, door #1. You indicate your choice to the gaurd and he says, "I cannot tell you how to escape, but I can tell you that door #2 will NOT lead to escape." Assuming that the gaurd is impartial and is telling the truth, what should you do?
-Stick with your original choice, door #1.
-Change to door #3.
-It doesn't matter, it's 50/50.
This is not an easy one, but it is also not a trick question by any means. Please justify (mathematically, if possible) any answer.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 23-02-2004, 20:44
Re: Odd Escape
i say go with 3
Unread 23-02-2004, 20:48
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Odd Escape
change to door #3.
when you chose door number 1 initially, you were chosing from out of three doors, and therefore had a 33% chance of getting the right one. with one of the wrong doors now eliminated, there are only 2 remaining. you are, however, still unaware as to wether or not your door leads to escape. if you stay with your door, you stick with the 33% chance you had originally. however, if you switch to door #3, you will have picked from 2, and your chances are now 50%.
i know it doesn't at first make sense, but I think that its right.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 23-02-2004, 20:56
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Re: Odd Escape
ah - ha
its the old Monty Hall problem from my statistics book.
Monty Hall had a game show "Let's Make a Deal" which dealt with the contestant choosing from 1 of 3 doors and then he'd reduce the number to 2 doors and you could choose again... or something like that. i don't really remember.
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 23-02-2004, 20:59
Team311's Avatar
Team311 Team311 is offline
School Is Boring
#0311 (Red Jammers)
Team311 will become famous soon enough
Re: Odd Escape
its easy ask the guard wich doors do not lead to escape
Unread 23-02-2004, 21:14
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Odd Escape
Originally Posted by Solace
change to door #3.
u picked 1 your onyl option left is 3 so how would picking three improve your chance? you still picked one of the 2 proper choices by choseing over again you dont improve your odds
EDIT: yes jake that just proves you are the head wombat cuz ur the smarter one
Unread 23-02-2004, 21:22
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Re: Odd Escape
Solace, you've got it spot on. Your 33% never changes, but the other door "takes on" the odds from the one that is eliminated, becoming 67%. It's a hard one to grasp, but you got it.
Another way to look at it: Imagine 1,000 doors, one that is correct and 999 that are wrong. You pick one randomly. The gaurd eliminates 998 others. Which do you think is more likely the right one? The one you chose randomly or the one the gaurd left?
I've seen this riddle argued on another forum for several pages, but there is no denying the answer....I was very surprised someone got it so quickly. Goes to show you that this forum has some amazingly intelligent people.
How about this one:
Option A) Play the same set of lottery numbers every week for 52 weeks.
Option B) Play 52 different sets of lottery numbers in one week.
Of course your odds of winning are pretty slim either way, but is one better than the other?
Unread 23-02-2004, 21:37
Solace's Avatar
AKA: Jake
Re: Odd Escape
does that mean i get a cookie? I like cookies.
...What is a man,
Jake
Team Paragon #571
Unread 23-02-2004, 21:39
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Re: Odd Escape
Score one cookie for Solace.
Unread 24-02-2004, 09:46
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: Odd Escape
hmm.... i so do not agree with that answer.... its more phycological.
Anyway... both options are the same.
There is an equal chance that a set of numbers will turn up and there is a chance that the same set of numbers turn up twice in a row. Some people just believe that it will be more likely to turn up if the same numbers are used every time.
Did you say 52 numbers? is the 52 numbers + a bonus ball or what?
cos here in england there is choice of49, and 6 numbers are drawn plus a bonus ball.
So really ,,, it makes no difference.
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 24-02-2004, 12:14
Re: Odd Escape
This question causes more heated debate than any other popular probability-based problem I know.
The answer is simple if you start out with the assumption that your first pick has one chance in three of being correct. From that, it should be obvious that your first pick has two chances in three of being incorrect, right? So if you switch, you have a 2/3 chance of switching away from a losing door.
After the other losing door is revealed and removed from your options, you end up having a 2/3 chance of switching to a winning door. It's good to switch doors. 1/3 of the time you'll pick the winning door to begin with and switch to a loser, but 2/3 of the time you'll start with a losing door and switch to the winner.
Unread 24-02-2004, 13:09
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Odd Escape
If I were the one asking the questions then I would throw in the free door to get the person to reconsider their first choice. By the way you are chosing then I would always have the upper hand. Therefore I always stay with my first choice as it is most likely right.
Remember that if you have a 67% chance of chosing the right door then you also have a 67% chance of chosing the wrong one. Optimist of pesimist your choice.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 24-02-2004, 15:41
Frank Toussaint Frank Toussaint is offline
Frank Toussaint will become famous soon enough
Re: Odd Escape
Regarding:
>How about this one:
Here's a counter example:
Supose that there were seventy million possible sets of numbers to be played. Consider the following two options:
Option A') Play the same set of lottery numbers every week for seventy million weeks.
Option B') Play all seventy million different sets of lottery numbers in one week.
In option A' it is possible that your set of lottery numbers never comes up but in option B' you are certain to hit. Option B is better.
Unread 24-02-2004, 18:01
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
Re: Odd Escape
Originally Posted by Frank Toussaint
Regarding:
>How about this one:
Score the second cookie for Frank Toussaint.
It's so true:
http://www.gtplanet.net/forum/showth...threadid=34178
Unread 24-02-2004, 18:08
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Odd Escape
Regarding:
>How about this one:
yea and after playing seventy millinon diffrent combos in one week you will need to win the lotto after spending 70 million dollars on tickets.
Meeting FIRST People in odd places Jeff Waegelin General Forum 219 04-03-2012 13:10
Meeting odd people in FIRST places BandChick General Forum 23 27-10-2003 12:03
When the even and odd year/team rule will stop. LizJJury Rumor Mill 19 17-04-2003 19:11
Does anyone have this odd problem?? Adam Y. Motors 2 04-02-2003 16:39
Odd Email... Tom Schindler General Forum 10 13-09-2001 00:47
