Go to Post This may very well be the weirdest Chief Delphi thread of all time... - Ginger Power [more]
Unread 23-02-2004, 21:23
ungulation ungulation is offline
ungulation is an unknown quantity at this point
Pneumatic Mounting with Zipties?
Is it legal to mount the pneumatic components (i.e. regulator, tank, solenoid (not the compressor)) with zipties?
I think it made it through the flow-chart successfully, but I said it was "not a safety hazard".
How has your team mounted pneumatics in the past?
Thanks
Unread 23-02-2004, 21:28
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Pneumatic Mounting with Zipties?
lol our tanks are mounted with zipties. not the compresser!! we screw down regualtors, but i see no problem with ziptieing them. im not a sticler on the rules tho, so you may wana double check this one
"You're not a real programmer until all your sentences end with semicolons;"
Unread 23-02-2004, 21:35
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Yeah we are taking off all our bolts and screws and holding the entire robot together with zip-ties to save weight.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 23-02-2004, 22:05
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
We've done it with Zip ties, It works fine.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-02-2004, 22:07
Umm Errr...
Its legal but ugly. Of couse this late in the build no one will complain. Just what components do you want to mount w/zip ties?
1139 Alumni
Unread 23-02-2004, 22:09
Imaginary Friend
AKA: Kevin Li
Team Role: Student
If you do it nicely it can be barely noticeable, or even pretty.
Kevin Li
596 - Sciclones
Unread 23-02-2004, 22:14
I would like to mount a tank, a regulator, a solenoid valve, pressure sensor, and a valve to dump the air. I know the kit came with mounting hardware for the regulators, but I'm not totally sure about how to mount the rest.
Rickertsen2 also said it was legal, does everyone agree? I didn't see anything in the rules against it, but I'm not very well versed in the rules and intentions of FIRST.
Thanks for your help
Unread 23-02-2004, 22:15
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes it is legal, we've done it before.
Kevin Li
596 - Sciclones
Unread 23-02-2004, 22:35
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Yea, it's legal. We've mounted tanks with zipties in the past and it worked ok. I wouldn't mount cylinders or the compressor with zipties though.
Unread 23-02-2004, 22:39
dragonpaulz's Avatar
dragonpaulz dragonpaulz is offline
4 P3r$0n
AKA: Paul Shapiro
#0555 (Team 555)
dragonpaulz is an unknown quantity at this point
Send a message via AIM to dragonpaulz
we put zip ties on our tires.
we've been trying to figure out if this was legal or not.
Team 555 - Montclair High School
Trust, Love, and Magic
WebMaster of MontclairRobotics.org
Unread 23-02-2004, 22:43
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Of course, the correct way to mount the tanks and valves is to machine a bracket for each. However, zip ties are perfectly fine. If you are really concerned about appearance, and have a little weight to spare, hose claps work well too.
Zan Hecht
Unread 24-02-2004, 00:51
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
<start serious answer> (not my normal, flip, smart-alecky self) The very best thing I can recommend to you is to put down your tools, sit down and go through ALL the rules carefully and completely. Don't touch your robot again until you are finished reading. That may seem like a dumb recommendation three days before the ship date, but it is probably the most important thing you can do.
The questions you are asking, and your admission that you "are not very well versed in the rules and intentions of FIRST" is just waving a huge red warning flag at us. You may have averted one illegal parts use by working through the information in this thread. But if you don't know the rules then the odds are that you have accidentally installed multiple other rules infractions on your robot that you don't know about. Stop building, read the manual, and find as many of those potential problems as possible. It will be 1,000,000 times better to find them now while you still have some time to correct them, than to show up at a competition and have the inspectors disqualify your robot because you are not able to correct a rules infraction. And it will be a whole lot more efficient for you to learn the rules yourself than to post a gazillion questions about your robot on here and asking for everyone's opinion of the legality.
Just trying to help. Good luck! <end serious answer>
Geez, I managed to get through the whole thing without saying "RTFM"!!!
-dave
pneumatic arms Jesse Control System 1 06-02-2004 15:41
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
Pneumatic Connectors. Josh Hambright Pneumatics 3 22-01-2003 20:22
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
