Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 06-02-2004, 19:21
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Switching the Channel for Competition
We are coming up on having our local Media Day and I only have a switch to change the channel on the 2003 Controller. Has anyone come up with a way to change the channel for local competitions without having to connect to the offical Competition port?
Thanks in advance
Matthew
Unread 06-02-2004, 19:36
Re: Switching the Channel for Competition
without the competition port adapter all the OI run on the same channel - using the comp port adapter IS the way to change channels - why would you want another way?
all you need is one jumper on a DB15 - what could be simpler than that?!
http://www.innovationfirst.com/FIRST...nout_Guide.PDF
Unread 06-02-2004, 19:55
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
That is what I was looking for. It looks like the same from last year. I will have to check. Again thanks.
Matthew
Unread 06-02-2004, 23:10
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
We have craploads of dongles for the competition port. If you're referring to the UAH media day that we'll be at .... you're more than welcome to borrow one.
Unread 07-02-2004, 01:44
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
We wanted some blue LEDs flashing, so I jammed a paperclip in the right pins (I looked them up), played with the channal dipswitches, and got it set to 13. Now we have blue LEDs.
It's not that hard, just don't do anything dumb ;-).
AIM --> Woloi
Email --> ian@woloschin.com
Unread 07-02-2004, 23:24
KevinB's Avatar
AKA: Alum
For those of us too lazy to read the IFI paper ... the pins to jam the paperclip into are 8 and 12.
Unread 08-02-2004, 08:33
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
I have also set the channel to 13 but we are still getting red leds. What could I be doing wrong.
Matthew
Unread 08-02-2004, 08:43
I think you also have to set you team number to something other that zero?
Unread 08-02-2004, 14:39
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
Yea we have the team number set and everything is talking correctly. The only thing is the color led is red on whatever channel we set.
Matthew
Unread 22-02-2004, 21:17
Ferazel2001 Ferazel2001 is offline
Mac Junkie
AKA: Devon
None #0599 (Robodox)
Ferazel2001 is on a distinguished road
Send a message via AIM to Ferazel2001 Send a message via MSN to Ferazel2001 Send a message via Yahoo to Ferazel2001
Where are the "sheets" for this kinda thing? I noticed the Chatsworth box had a LOT more stuff in it then mine does, and that kinda bugged me... I had been looking for like 30-60 mins for the pinout guide for the CPT port. Could someone please direct me twords the resources they used or other people used for their comp port things?
Unread 22-02-2004, 21:24
KevinB's Avatar
AKA: Alum
I think this is all the general public knows about the port:
pin 1 - VCC (note that IFI says that using this pin will void your warranty)
pin 5 - Autonomous Enable
pin 6 - Disable
pin 8 - Ground
pin 12 - Enable Channel Select
Unread 22-02-2004, 21:29
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
hahaha thats counting from the left or from the right *whoops* i guess it was the other way
"You're not a real programmer until all your sentences end with semicolons;"
Unread 23-02-2004, 15:29
Mac Junkie
AKA: Devon
Whats VCC?
is that a thing that would be used in the actual competitions?
Has someone fried their system yet using that port?
Unread 23-02-2004, 22:27
KevinB's Avatar
AKA: Alum
They're labeled on a standard 15 pin connector.
Unread 23-02-2004, 22:30
KevinB's Avatar
AKA: Alum
Whats VCC?
VCC is a direct connection to the OI power. You could use this pin to provide the operator interface with a power supply (connect a 9v battery to pins 1 and 8). You can also use this pin to *get* power from the operator interface (to power LCDs or the similar).
The reason IFI doesn't want people messing with this pin is because it is a direct connection to voltage and could fry the OI if you're not careful. That said, we've never ruined an OI -- one time we shorted some of the wrong pins on the competition port and it started going crazy but a power cycle fixed that problem.
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
Science Channel 2004 FIRST Video Ralph Lambert General Forum 26 22-10-2003 20:20
Channel 1 News archiver 2001 0 24-06-2002 03:08
Robots and the Learning Channel.... archiver 2000 0 24-06-2002 00:16
New First Robotics Discussion IRC channel Andrew Wyatt General Forum 10 07-12-2001 06:25
