Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 23-02-2004, 23:40
danielkitchener's Avatar
danielkitchener danielkitchener is offline
408 Computer Nerd
AKA: Daniel Kitchener
#0408 (Roboticks)
danielkitchener is on a distinguished road
HELP!!! Counters, global variables, and the like
Well, here's a question with an answer that's probably very obvious. How do I create a counter used by both the default routine and process IO functions? I tried declaring a global variable, but MPLAB had a major case of PMS when I did. Perhaps I'm doing it wrong? Below the includes, I simply declared
int counter=0;
Is there a better way of doing this?
Also, how do I pass values between functions? Once again, the compiler gets testy
This is urgent, as we ship in 2 days
Unread 23-02-2004, 23:42
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
Re: HELP!!! Counters, global variables, and the like
well... if they are in separate files, you need to declare it in each file... do
int count=0;
in one file, then do
extern int count;
in all the others.
Unread 23-02-2004, 23:53
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
dont forget you get to work on programing after you ship
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
