Go to Post yes, duct tape solves everything - Ted Boucher [more]
Unread 21-02-2004, 14:42
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
GeneratePWMS
I'm trying to read in a PWM. How do I do this?
On the edubot, they have the "setup who control pwms" function that changes the pwm_mask variable in the tx_data struct, but what does this do for me? This variable exists in the FRC code, so I can change it there, but I don't understand how this gets me input since there is no place for pwm inputs in the rx_data structure.
Unread 21-02-2004, 14:46
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Re: GeneratePWMS
Why do you want to use a pwm as an input?
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Unread 21-02-2004, 16:55
Re: GeneratePWMS
some sensors allow I2C input or PWM input, and we don't have access to the I2C
Unread 21-02-2004, 18:44
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: GeneratePWMS
I believe that there are a few #define statements in one of the header file that change PWMs 13-16 to either IFI_PWM or USER_CCP. That might be what you're looking for...
Unread 21-02-2004, 20:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: GeneratePWMS
No, that's not it. The Setup_PWM_Output_Type() function is to set up the specifics of the PWM signal. if you don't use IFI_PWM for all 4, you have to set it up yourself (see comment in the default code). this is done in User_Initialization().
Unread 21-02-2004, 20:30
Re: GeneratePWMS
I think that that's what I was talking about, sorry, I didn't have the code in front of me...
Unread 23-02-2004, 23:26
Re: GeneratePWMS
Thanks guys. I found a way to do it. Took some experimenting, but here it is:
Run the sensor output into digital inputs 2 and 3. Have interupt on 2 for the rising edge and one for the falling edge. The first starts the timer, the second reads it out and scales it.
I haven't actually tried this - I'll probably fool with it post-build season, but I was just thinking ahead since my team doesn't let me touch the bot. Something about building it....
Unread 24-02-2004, 00:56
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: GeneratePWMS
You don't have to do it like that. Dig I/O pins 3-6 are interrupt on change, so just plug it into dig io pin 3 and when RBIF triggers check to see that it is indeed pin 3 that changed (since 3-6 all trigger the same flag). You can sense both rising and falling edges on the same pin.
Unread 24-02-2004, 01:05
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: GeneratePWMS
Just FYI, interrupts 1 and 2 can also exhibit this behavior if you flip the INTEDGx bit in the interrupt handler. As a starting point, I'd suggest using the code in receiver.c/.h because it pretty much does exactly what you need to do (pulse width discrimination). I'm not sure if it's usable (IFI may have wired-in a output buffer on the CCP pins), but you might also look into using the CCP Capture mode to do this.
-Kevin
Kevin Watson
http://kevin.org
