Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 24-02-2004, 00:58
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Wait4TXEmpty
Is it necessary to call Wait4TXEmpty() in ifi_utilities?
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 24-02-2004, 01:12
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: Wait4TXEmpty
There is a slight delay between the time when you put a byte in the Tx buffer and when that data is actually sent over the Tx pin. TXREG is just a holding register for data you want to sent over the Tx pin. The chip will load the data from TXREG into the transmit shift register once the stop bit from the previous byte is sent over the Tx pin. Once data from TXREG is loaded into the shift register, TXIF is set, signaling TXREG is ready to receive more data.
If you try to write another byte into TXREG before TXIF is set, that byte that used to be there will never be transmitted.
So if you have enough of a delay between writes to TXREG, you can get away with not calling Wait4TXEmpty(), but it's better to just call it.
Unread 24-02-2004, 08:21
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Wait4TXEmpty
Following on with Jay's comments the real requirement is that the TXIF is set before writing the next character. If you are doing processing between characters it might be better to check TXIF before you send not wait for it to change after you send.
- Gene Falendysz
