Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 09-02-2004, 18:09
bob1million's Avatar
bob1million bob1million is offline
#0825 (Swivvey-gus Maximus)
bob1million is an unknown quantity at this point
Purchasing double solenoids
We have been looking to buy some doulbe solenoids so we don't have to destroy last year's bot for them. The best offer we got so far is $95 and that is too much. Does anyone know where we can get some cheaper?
"Death smiles at us all, all a robot can do is smile back."
Unread 09-02-2004, 20:12
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
Re: Purchasing double solenoids
as far as I was aware, you can ONLY use this years solenoids, or solenoids from previous years, so buying new ones is probably illegal. if you were buying new ones to put in last years robot, however, then graverobbing the old ones for this years, then your probably straight.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 09-02-2004, 20:21
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I am sorry for not having an answer for the original question, but this isn't true. You can use as many actuators, solenoid valves, and fittings as you want, as long as they're "off the shelf" and as long as you account for them in your costs sheet. See The Robot, page 7.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-02-2004, 20:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
To be specific:
<R54> .......
• There is no limit to the number of solenoid valves, air cylinders, and connecting fittings you may use on your robot. They must, however, be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi. Besides the “free” pneumatic components listed on the Pneumatic Components Order form, you may use additional air cylinders or rotary actuators, however, they must be identical to those listed on the Pneumatic Components Order form, and obtained from a Bimba or Parker Hannifan distributor.
• You may use a previous year’s Kit pneumatic cylinders and solenoid valves in addition to those items in the 2004 Kit, but you must account for their costs as explained in the Cost Limits and Accounting section.
Unread 09-02-2004, 20:32
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Call motion industries (there should be a local branch in you area).
The part number of the SMC double solenoid is SY3240-6LOU (I am not sure what the part number for the base is), we purchased ours for ~ $65 a piece.
Hope this helps.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 24-02-2004, 08:25
tminard tminard is offline
#0902 (Delphi Automotive Saginaw / Heritage High School)
tminard is an unknown quantity at this point
Hope this helps.
SMC is out of stock on the current double solenoid valve, does anyone know where we can get an alternative supplier? Is there another valve that does the same thing that is available? There is a couple week wait for parts from Japan! Anyone got any ideas?
Unread 24-02-2004, 08:49
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
yeah SMC is out til sometime in april from what I hear....though there is an upside....go find an equivalent in another company (yes it is legal check the Q & A) and get an equivalent double solenoid from them....
Unread 24-02-2004, 12:16
Have you checked the availability of other option selections of the same model? There are many different configurations available, some of which are more common than others. The SY3240-6Mxxx might be available, while the 6L might not be, and the only difference is the orientation of the electrical connections.
I suggest you try to find help with your local distributor, at this point. Talk to them, tell them about robotics, and see if they can help you find what you need. Bill and I just ordered some, yesterday, UPS RED from Indianapolis.
Unread 24-02-2004, 13:06
Generator of Entropy
FRC #2973 (The Mad Rockers)
Here's what we worked out with our local SMC rep (HPE Automation in Deerfield Beach, FL - talk to Julie at 954-429-9560) when we found the others were not available:
SY3220-6LOZ-N7 ($69.45 each including the connectors)
I just talked to her, she said there are about 40 left in the country
This is body mounted using 2 M3 screws (or tie wraps), the N7 adds no. 4 QD fittings to the top for ports A and B, they need to order the connectors separately from Atlanta (if you don't need them it saves you a few bucks - same connector as other SMC valves), and you'll need to add a 10-32 straight thread to no. 4 QD fitting to the supply side (available from McMaster Carr - this fits fine in the metric port). It makes a nice flat package - it's basically the same as the 3240 (which is base mounted) in the kit except for the port locations and it already has QD's.
Unread 22-04-2004, 10:28
JBabbie's Avatar
JBabbie JBabbie is offline
JBabbie is on a distinguished road
we bought double solenoids this year and WOW!!! they are expensive... we got them for $75.00 a piece!
SCREAMTEAM-CLICKY!
Unread 23-04-2004, 14:16
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Talk to Biff. He got us the solenoids we used in our bot (they also have a nuetural position, meaning you can do multi-pos pneumatics easy)
Unread 08-07-2004, 03:17
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Just a note on Astronouth's comment aboout multi position pneumatics with the center position, be careful what three position (double solenoid) valves you get.
Some, like the ones that came in the kit are all ports blocked in the center position, others are all ports open (except the line in, of course) meaning in the center position all the air pressure from both ends of the cylinder would be released.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
FIRST Double Jeopardy! (8/27) EddieMcD Games/Trivia 2 28-08-2003 21:41
Double Solenoids - assembly. Frank(Aflak) Pneumatics 9 06-02-2003 20:33
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
Solenoids archiver 2001 9 23-06-2002 23:47
