Go to Post When in doubt, ask... don't assume (unless you don't mind wasting time/money). - Bill Gold [more]
Unread 23-02-2004, 22:48
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Dead Reckoning
Is there a way to speed up the compile, linker cycle for testing out dead reckoning values? At this current moment it takes about 4 minutes on the teams workstation (we just got a usb -> serial so it may work faster on a laptop) to compile and link from scratch and then about 2 minutes to update and recompile the autonomous code. To make the code compile faster I completely put the autonomous routines in a seperate file so only those would be recompiled... Yeah, so any ideas?
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 24-02-2004, 07:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Dead Reckoning
Use F10 instead of the make button. It won't delete the o files and will only compile what you changed.
Unread 24-02-2004, 09:13
Re: Dead Reckoning
when there is no changes to the code, the compiler runs right though them no matter whether you use the make button or the make access key.
Unread 24-02-2004, 10:57
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Dead Reckoning
yeah... the "make" function in MPLAB acts the the "Rebuild All" function in MSVC - it deletes all of the .o (object) files and recompiles. If you compiled things by hand (or using a makefile), you could have it only recompile the necessary objects, and then just link again...
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Answers for Dead Reckoning... FOR BEGINNERS actorindp Programming 6 20-02-2004 23:56
What to do with autonomous Rickertsen2 Programming 48 17-02-2004 16:22
Autonomous Mode Strategy Brian48216 Programming 27 23-01-2003 14:47
dead robot in the finals? srawls Rules/Strategy 2 24-03-2002 14:44
