Go to Post Don't rely on the field staff to get every ball to work with your machine....engineer a robot that makes the change not matter. - PayneTrain [more]
Unread 23-02-2004, 19:30
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
How to program servos
That line was it......please help.
~Bstemp
Unread 23-02-2004, 19:48
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: How to program servos
Treat them just like you would a motor, except that instead of outputting a speed from -127 to +127, you are outputting a position from -127 to +127. For fun, you can hook the servo to the PWM outputs for one of your motors, and play with the joystick to get a feel for how they work.
Zan Hecht
Unread 23-02-2004, 20:51
Captain
Team Role: Student
didn't work....any possible problems/solutions?
Unread 23-02-2004, 22:31
Have you connected a good 7.2v backup battery? That's where the servos get their power.
Unread 23-02-2004, 23:45
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
-127 to +127?
I thought the readings had to be from 0 to 255...
Are you just adding 127 to the outputs at the end of your main loop?
Can you actually use +127 .. -127 and I just havent heard about it?
What didnt work? Did the motors just not move?
If you hook a victor up to the outputs, does the little orange light go solid?
If it dosent, it means that theres a problem with the code (probibly), and if it IS solid orange, and changes from green to red when you change the signal being sent to it (moving the joystick), then your servo is probibly broken.
Also, I read somewhere that last years servos dont work. That might be it.
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 24-02-2004, 08:27
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Originally Posted by wun
-127 to +127?
You do need to send 0 to 254! You get about 120 degrees of motion from the servo with that range and yes the 7.2 battery is required.
- Gene Falendysz
Unread 24-02-2004, 11:48
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
it realy doesnt matter, as long as its a char variable, it doent matter weather is singed or unsigned. And make sure whatever pwms your using are enabled, not used anywhere else and arnt set as digital i/os
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 24-02-2004, 13:45
Captain
Team Role: Student
Gene F is the man and God of all hardware. I thought that battery was for back up purposes only. I haven't tried it yet, but I'll plug in that battery. I know my code is correct, so it should work. Thank you guys for your help.
~zBStem
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
