Go to Post I also exclusively use FRC team numbers when punching in times for the microwave. - Calvin Hartley [more]
Unread 23-02-2004, 19:02
2Crisis's Avatar
2Crisis 2Crisis is offline
Blaarg
AKA: Dave L
#1343
Team Role: Webmaster
2Crisis is an unknown quantity at this point
Send a message via AIM to 2Crisis
Question Banner Sensor Programming Problem
I am having some trouble with the Banner Sensors (for detecting the white reflective line). We have the Banner Sensors wired up as I have read here in the forums (white OR black for Data on RC, blue for ground, brown for +). We currently have 2 Sensors: Sensor #1 is plugged into RC Digital IO port 1, and Sensor #2 is plugged into RC Digital IO port 18 (we have to use port 1 and 18 because our pin-wire connector is too fat on one side). When we power on the robot (and neither banner sensor detects anything), rc_dig_in01 broadcasts 257, and rc_dig_in18 broadcasts 0. If Sensor #1 detects something, rc_dig_in01 accordingly broadcasts 1. However, if Sensor #2 detects something, instead of changing rc_dig_in18 to 1, it changes rc_dig_in01 to 256, and rc_dig_in18 stays at 0. rc_dig_in18 is ALWAYS broadcasting zero! If both sensors detect something, then rc_dig_in01 broadcasts 0. I'm fairly certain this is a programming problem, but I am lost. I have 'rc_dig_in18 = INPUT' set in the User_Initialization() function, but can rc_dig_in18 not be programmed for Input? In the default_routine, it reads
relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
So, what's going on? Can rc_dig_in18 only be used for some kind of pressure switch? I'm lost.
Unread 23-02-2004, 19:16
Re: Banner Sensor Programming Problem
Im more lost than you are - a digital input should only be able to give a value of 1 or 0
I have no idea how you are getting 256 or all those other values from a single bit pin
try searching your code on the variable names - maybe there is a stray equation someplace that is setting the bit variables to something else?
this is really strange.
Unread 23-02-2004, 21:08
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
the input you he's getting on rc_dig_in01 is actually 0 and 1, but it's being printf'd without being cast to an int - thus, the unsigned char value is being taken along with a second byte of padding, thus 0 + 256 = 256, and 1 + 256 = 257.
2Crisis, when you printf values, make sure you do it like this:
printf("dig in 1: %d", (int) rc_dig_in01);
make sure you have the banners wired correctly - the blue and brown wires for both sensors should be hooked up to a 20 amp fuse on your fuse panel, and either the white or the black wire (the same color for both sensors) should be hooked up to the SIG pin of the digital input port.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 23-02-2004, 21:37
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
We had a similar problem...in fact, it was exactly the same. We were getting 257 also and wondering how that was possible. Well, turns out the sensors were working fine, it was just printing the wrong numbers, if that is possible. Try printf-ing one at a time. I'm sure there is an explanation, I just have no idea what it is.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 24-02-2004, 13:40
2Crisis's Avatar
Blaarg
AKA: Dave L
#1343
Thanks guys, it works now. I forgot about those unsigned chars . When the #2 Sensor was plugged into rc_dig_in18, it still broadcasted a constant zero no matter what I did, so we soldered on new ends, and moved it to a different IO port... it now works correctly.
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
