Re: Using two spikes for one motor
For each spike there are 2 variables for programming. One is relayX_fwd and the other is relayX_rev. By setting both to 0 it is the same as setting a Victor to 127. It is a neutral position. By setting either the fwd or rev variable to 1 would indicate which direction it will run. Just don't set both to 1 because that won't work.
Thank you very much!
Take the case that you are controlling two pneumatic devices with a single Spike. Electrically you would connect one pin of each of the solenoids to ground and the other to either the M+ or M- on the Spike. Then in software the relayX_fwd controls the device plugged into M+ and relayX_rev controls M-. (Note that you only get on/off functionality with this method) By setting both to one, both devices would be controlled. |
| Thermal Protection | archiver | 2000 | 1 | 23-06-2002 23:27 |
| Window motor tape | archiver | 1999 | 4 | 23-06-2002 22:04 |
| Gear/Sprocket Help | Joseph F | Motors | 3 | 18-03-2002 07:48 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drill Motor and FP Motor Shaft Diameters | Andy Baker | Motors | 4 | 11-06-2001 20:12 |
