Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Unread 24-02-2004, 14:23
supergrover supergrover is offline
AKA: Chris Warren
FRC #1397 (Ajax Rams)
supergrover is an unknown quantity at this point
Using two spikes for one motor
We were wondering if we can place two spikes for one motor. We are out of victors, so we were wondering if we could somehow use one spike for forward, and another for reverse (using the same motor for both directions).
Thanks for any/all help!
Unread 24-02-2004, 14:35
Re: Using two spikes for one motor
you only need one spike to get forwards and reverse - thats how they work.
only restriction is you are not allowed to use spikes for the drill or chip motors.
Unread 24-02-2004, 14:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
you are not allowed to use them for the Fisher Price also, if i am not mistaken
Team 1257
Unread 24-02-2004, 14:43
AKA: Chris Warren
thanks for the help guys....but we thought we could only use them in one direction....on or off...so how do we make them go forward and reverse?
thanks guys for the quick response
Unread 24-02-2004, 15:12
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
For each spike there are 2 variables for programming. One is relayX_fwd and the other is relayX_rev. By setting both to 0 it is the same as setting a Victor to 127. It is a neutral position. By setting either the fwd or rev variable to 1 would indicate which direction it will run. Just don't set both to 1 because that won't work.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 24-02-2004, 15:19
AKA: Chris Warren
Thank you very much!
Unread 24-02-2004, 15:36
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
This is true in this case Chris, but as an FYI it can work in some cases.
Take the case that you are controlling two pneumatic devices with a single Spike. Electrically you would connect one pin of each of the solenoids to ground and the other to either the M+ or M- on the Spike. Then in software the relayX_fwd controls the device plugged into M+ and relayX_rev controls M-. (Note that you only get on/off functionality with this method) By setting both to one, both devices would be controlled.
Thermal Protection archiver 2000 1 23-06-2002 23:27
Window motor tape archiver 1999 4 23-06-2002 22:04
Gear/Sprocket Help Joseph F Motors 3 18-03-2002 07:48
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
