Go to Post You need to stay on top of your classes or you will be back as a returning freshman on next year's team. - [more]
Unread 24-02-2004, 16:22
FormatteD_C's Avatar
FormatteD_C FormatteD_C is offline
owned?
AKA: Matt Kerr
#1206 (Wrench Warriors)
FormatteD_C is an unknown quantity at this point
Send a message via AIM to FormatteD_C
Inverting Y axis on joystick
Hey,
We need to invert the Y axis and I don't know how I would code it, any input on this would be great.
Unread 24-02-2004, 16:25
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: Inverting Y axis on joystick
All you have to do is subtract your current value from 254. I think you can just do p1_y=254-p1_y; but just to be safe I would use a temp variable. Sooo, temp=254-p1_y; then just use temp instead of p1_y (or whatever joystick port) in your program.
Unread 24-02-2004, 16:40
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Woulden't it be temp = 255 - p1_y? Because other wise you can have negative numbers.
Unread 24-02-2004, 16:42
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If p1_y == 0, then that would evaluate to 255, which is an invalid PWM output. If you're using an unsigned data type, it can't be negative, anyway.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-02-2004, 16:47
AKA: Jamie Bliss
Oh, right. But I think the joystick vals go up to 255.
Unread 24-02-2004, 16:51
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
temp = (p1_y == 255) ? 0 : (254 - p1_y);
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 16:52
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
255 is not a valid output on a PWM. I think 3 consecutive 255's result in a reset or something.
The range is 0-254, so you want:
p1_y = 254 - p1_y;
No need for a temp variable, the compiler will handle that just fine.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 24-02-2004, 16:56
AKA: Jamie Bliss
Ok, thank you for correcting me. Though I could've sworn I saw 255 on dashboard... Oh, well :shrug:
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
