Go to Post I hate having to wear official pants. - Cothron Theiss [more]
Unread 24-02-2004, 19:01
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
Problems with MPLAB
I got the following error when trying to build:
C:\Documents and Settings\donnyb\Desktop\FIRST\Frc\Rev 03\ifi_aliases.h:18: malformed #include directive
error 1 spawning c:\mcc18\bin\cpp18
MPLAB has not been used on this computer yet, but all the files have built correctly on our other computer. So... is it a software problem?
Thanks,
Char.
Team 1350
Manchester 2003 Rookie All Stars
Unread 24-02-2004, 19:35
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Re: Problems with MPLAB
I think that the problem is that the path is too long. MPLAB has a problem with paths that are more than 32 characters. Try a shorter path.
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Unread 24-02-2004, 19:36
Thanks,
Char.
One problem is your project is too far down in the directory tree. Move FIRST to the top level of your C drive, e.g., "C:\FIRST\Frc\Rev 03"
Unread 24-02-2004, 19:47
Charley's Avatar
None #1350
I just fixed that, now the same error occurs with the new directory
Team 1350
Unread 24-02-2004, 20:43
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
New message, please? Have you tried reinstalling MPLAB? Did you install from the CD included with your Edu Robot/controller? Did you follow the FIRST specific installation instructions? Did you miss installing the C18 compiler?
Unread 24-02-2004, 21:11
Paradox1350's Avatar
Paradox1350 Paradox1350 is offline
FORMER Captain now Jealous Onlooker
None #1350 (Rambot)
Paradox1350 is on a distinguished road
I'm on Charley's team. We have not tried reinstalling. We lost the disc that came with the EDU bot kit and transfered the files from one computer to the laptop that we have. The program works on the original computer, but not the laptop. I have no idea whether or not we are missing the C18 compiler.
Unread 24-02-2004, 21:14
Do you have a "c:\mcc18" directory? That's the compiler.
The error you are getting occurs the first time you try to access a file in the mcc18 directory called adc.h
This can occur if it is missing, but also if your MPLAB project is not set-up correctly. You can check under Project->Build Options...->Project to see everything's set properly.
Include Path c:\mcc18\h
Library Path c:\mcc18\lib
and for good measure under the MPLAB C18 tab is _FRC_BOARD listed under Macro Definitions?
Unread 24-02-2004, 21:32
None #1350 (Rambot)
We do have a "c:\mcc18" directory.
Message: "error 1 spawning C:\mcc18\bin\cpp18" after I verified the build options were set properly. I have no idea what this means!
Unread 24-02-2004, 21:36
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
i'm willing to guess it just means that mcc18 didn't like something you sent it, hence the "malformed #include directive" error - look at line 18 in ifi_aliases.h and see if someone accidentally bumped a key and inserted a character or something.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 21:59
zeep25's Avatar
zeep25 zeep25 is offline
AKA: Adil Karim
#0369 (Team Nuts and Volts)
Team Role: Webmaster
zeep25 is an unknown quantity at this point
Send a message via AIM to zeep25 Send a message via Yahoo to zeep25
wait so ur saying u didnt have the mplab cd so you copied the files (the mplab and mcc18) from the other computer where it works :s ?
if so try this ... remove the directories and download the MPLAB[30 Megs] and mcc18 (demo)[10 megs] from the microchip website
and install the mplab first and tghen mcc18 ... make sure when ur installing mcc18 you check on when it asks you to configure mplab to use this version of mcc18 and stuff ...
if you didnt copy the files over and installed them ... try removing them from add/remove program and then do a fresh clean installation (as mentioned above)
btw what is the directory path to the files now ?
Roles: Programmer, Webmaster, (All rounder) including Electrical and Mechanical
Gearbox - Team Nuts and Volts - 369
http://www.gearbox36.org/
Unread 24-02-2004, 22:25
Check the toolsuite locations.
under Project->Select Language Toolsuite...
Under Toolsuite Contents "MPLAB C18 C Compiler (mcc18.exe)" should be listed.
Click on that line and see that the Location shows "C:\mcc18\bin\mcc18.exe"
Unread 25-02-2004, 09:50
Descartes's Avatar
Descartes Descartes is offline
Team Philosopher
AKA: Ryan
#0378 (Circuit Stompers)
Descartes has a little shameless behaviour in the past
We had the exact same problem, same errors and everything. Its turns out its an occasional MPLAB bug where the compiler cannot locate the Language Toolsuite , even if you have it pointing right at it. We actually tried the exact method that McLeod there suggested. Didn't work. Only solution we found was to back up your source code and uninstall and reinstall MPLAB.
"The longer one holds on to a memory... the longer one lives in the past. The deeper the memory they hold onto is... the more beautiful the past will become. The beautified memories will eventually turn into hate... Even if they look ahead, they lose the ability to walk. As long as the heavy chain called Revenge continues to fetter the heart. As long as the tears of sadness continue to flow."
"Dangerous toys are fun, but you could get hurt!"
"The Deadly Dodgeball Head! A simple technique to hold the ball in place with intense suction! Try this at home kids!!"
"I am known as Valentinez Alkalinella Xifax Sicidabohertz Gombigobilla Blue Stradivari Talentrent Pierre Andri Charton-Haymoss Ivanovici Baldeus George Doitzel Kaiser III. Don't hesitate to call."
Unread 25-02-2004, 10:28
Just curious, what version of MPLAB are each of you using?
We're running MPLAB 6.4 downloaded from the Microchip site, rather than the 6.3 version shipped with the EDU Bot.
Unread 25-02-2004, 15:12
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Is there a cpp18 there?
I think it's more likely that it means that when it encountered the #include directive, and went to spawn cpp18.exe (the preprocessor) it didn't find it in C:\mcc18\bin where it expected to find it.
Unread 25-02-2004, 15:29
Descartes's Avatar
Team Philosopher
AKA: Ryan
The problem occured on our backup PC, while I was updating it. Our main computer for programming had the up - to - date version, but the backup did not.
Incidentally, I discovered another solution. Under "Projects, Build Options, Project." Click on the General tab. If your Include Directory does not have anything in it, point it at the c:/mcc18/
This worked for us.
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
Im Having Problems With Mplab!!!! hedgehogger Programming 2 20-01-2004 17:43
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
