Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 24-02-2004, 21:27
alexrobotics alexrobotics is offline
alexrobotics is an unknown quantity at this point
Bringing in Navigate.zip into the Default code
Hello,
We are wondering if anybody has some information on how to bring the navigate.zip into the default code. What are the steps required to do this? Since the current sensors are mentioned in the navigate.zip code will they affect the other functions when not in autonomous mode? Hey thanx for the help guys.
Unread 24-02-2004, 21:42
Re: Bringing in Navigate.zip into the Default code
Originally Posted by alexrobotics
Hello,
It was talked about here http://www.chiefdelphi.com/forums/showthread.php?t=24631. In addition to those instructions you'll also need the navigate.c and navigate.h files, and you'll need to add a call to navigate() to the User_Autonomous_Code() routine in the user_routines_fast.c file.
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
