Go to Post All I want for Christmas is a better game hint, a better game hint, a better game hint... - Schnabel [more]
Unread 24-02-2004, 20:45
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
IR code
Ok, so we put the sensors on rc dig in 1, 2, 4, 5 and servos on 1 & 2.
Then the drives on 13 and 15.
Uploaded navigate.zip and..........pwm03 fires at 72 whether auton is enabled or not and the servos do not do anything unless you reset and they twitch a little....any help would be appreciated.
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
Unread 24-02-2004, 21:31
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: IR code
a) navigate.zip is designed just to run, it's not set up to be only running in autonomous mode (you have to do that yourself)
b) if I remember correctly, the IR sensors go on ports 3,4,5, and 6, starting with the left-most and ending with the right-most.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 21:36
Re: IR code
If you are using navigate.c as-is then it's waiting for you to hit one of the joystick buttons (p1 trigger).
Your hook-ups seem to be correct.
It needs to be modified to be used in competition.
It was talked about here [thread]24631 [/thread]
In addition to those instructions you'll also need the navigate.c and navigate.h files, and you'll need to add a call to navigate() to the User_Autonomous_Code() routine in the user_routines_fast.c file.
Unread 24-02-2004, 22:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR code
Read the FAQ, Luke (Okay, okay, so I saw Star Wars a few too many times).
-Kevin
Kevin Watson
http://kevin.org
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Operator Interface code RiotingNerd Programming 5 07-02-2004 21:13
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
