Go to Post I don't think it's that big of a deal if FIRST makes a few mistakes or cuts back every now and then. Personally, I'm just glad I have the opportunity to be in this program. - Crop-Circles [more]
Unread 24-02-2004, 21:28
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
pnumatic programing
our team has the bot basicly done and so i have a day to work on the code. right now everything works but i have noticed one thing. when you push the button/move that hat to accuate the cylander, the spike stays in the position after you let go. this can be fixed with a simple "else" statement. but should it be? is it a problem if the valve is continuously open? is it better if it closes after a certin period of time or when the user releses the button? im not a pnumatic guy, i just write the code. i supose the only benifit that i could see is that there is a constant current drain if you leave it on, there isnt if it shuts off. thanks all.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 24-02-2004, 21:34
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: pnumatic programing
it depends. are you using a double-acting solenoid or a single-acting? Single-acting solenoids will go back to their default position if the circuit is broken, while double-acting ones will stay in their last position.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 21:35
AKA: theshadow
FRC #0620 (WarBots)
were using 2 double solonoids... 2 wires each with 1 spike per, a diode and a common ground.
Unread 24-02-2004, 21:39
Computer Guy
AKA: Dav
then it doesn't really matter whether you apply power momentarily or constantly - although as you said, constant power = constant power draw. Thus, you might make it only be momentary power, say for 500ms or so.
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
Are u using a double or single solenoid for this action ur talking about?
W/ the single solenoids the power has to be continues (relay foward) in order for the cylinder to remain in that posittion (extended for instance) once power is removed it will return to the other posittion (retracted). Note: this only applies to Single Solenoids !
hope this helps
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 24-02-2004, 21:41
Computer Guy
AKA: Dav
hope this helps
try reading the entire thread next time...
Unread 24-02-2004, 21:45
AKA: "The Freshman"
Team Role: Operator
I did , but at the time i began typing my reply only the original post was there. Im a little slow w/ my response time, i only realized after i posted that u had already answered the question
Unread 24-02-2004, 21:48
AKA: theshadow
FRC #0620 (WarBots)
thanks guys. i think im just gonna have it release when they let go of the button. saves me a variable, timing and makes it darn easy. and besides, people cant hold a button for less then 500ms anyway. thats a SHROT time in people time
Unread 24-02-2004, 21:49
Computer Guy
AKA: Dav
eh, no biggie
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Programing great_one411 General Forum 2 01-02-2003 17:27
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
Who is doing the programing for team 61 Walter_Jr Programming 5 25-01-2003 00:31
Programing of controller DLyons Robotics Education and Curriculum 2 02-12-2002 00:16
