Re: Back up battery
From what i saw on the First Q&A any 7.2 volt nicad battery pack is allowed, but u cannot make your own battery pack to use for this purpose.
"Q: The RC backup battery has to be yellow? A: No. Use the Edubot or any 7.2V NiCad battery. See R39." "Q: Can we use a battery pack that we assembled ourselves, using 6 AA NiMH cells? They have the same voltage (1.2V x 6) as NiCad cells, but more capacity (1600AH) and no memory effect. A: No. See R39." |
Re: Back up battery
You can buy the connector from Innovation First for $3.50, if you already have the battery pack. |
| What if FIRST changed back to 2 coaches? | D.J. Fluck | General Forum | 45 | 08-01-2007 18:25 |
| Jump Start RC w/o Exide 12v battery | Mark McLeod | Control System | 3 | 12-01-2004 12:42 |
| Quick release battery connector and 120 amps | n[ate]vw | Electrical | 6 | 18-01-2003 23:41 |
| Off-topic battery stuff. | FotoPlasma | Electrical | 4 | 06-01-2003 12:19 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
