Go to Post Anyone riding a Segway looks cool...ask Andy Baker - Kyle Love [more]
Unread 25-02-2004, 00:58
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: WHich motor to lift and for arm
Yes you will. Or some other device to stop it from backdriving and blowing its worm gear.
Unread 25-02-2004, 01:03
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Our will stop without the ratchet. We will probably add one anyways though. Our winch diameter is <5/8" though. Small diameter helps.
Unread 25-02-2004, 10:16
Ours is exactly 5/8" and a combination of that and the adjustment screw and the van door motor doesn't back drive. It all depends on how fast you want to go, how much energy you want to use, and how complex you want your system to be.
Unread 25-02-2004, 10:20
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
our winch is directly connected to the drive train, so we have 2 drills and 2 fischer prices running it. those have more power than the van door, but stealing power from the wheels requires a lot of planning and is probably not something you can add on at this point
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 25-02-2004, 10:34
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I would suggest that you look in the White Papers technical section for the papers on motor selection. Ken Leung has done a nice job of compiling info from Joe Johnson and others that will let you select a motor and gear ratios to keep from smoking motors. The key is determinig the Power you need first and then adjusting the motors to get the required torque.
The examples can be used as 'recipes' for lifting balls and robots. We used these notes this past year to select dual Fisher Price gearboxes to lift twice the weight of our robot straight up in under 10 seconds. We have not tested the twice the weight yet but it gives us a good safety factor.
Andy Brockway
Team 716, The Who'sCTEKS
