Go to Post Remind me again why anyone, my team included, is stupid enough to keep going to week 1 events? - Madison [more]
Unread 25-02-2004, 07:27
Re: Urgent!! (programming question)
if you used pbasic in prior years, you might have used the debug statement. This year in C it is printf(). What you need to do is find the placein your code where you want to print a variable and for example write
printf("Motor 1 = %d/n" motor)
Whats in quotes will be displayed on screen when you use the hyper terminal, and the %d is used in quotes to show you want to display a decimal value. the /n is a line feed.
Unread 25-02-2004, 09:12
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
printf("Motor 1 = %d/n", motor)
Don't forget the comma if you happened to copy his code. You will also want to add an explicit cast to the printf. So, something like this:
printf("\nMotor 1 = %d", (int)motor);
Just replace the motor with the pwm you want. For a joystick, do something like this:
printf("\nPort 1 Y = %d, Port 2 X = %d", (int)p1_y, (int)p1_x);
You can change the port that it is outputing to whatever you want.
Or, if the values don't change too fast, you could always just use the Dashboard from the Innovation FIRST website.
Unread 25-02-2004, 10:35
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
You can log and plot about 15 seconds worth of data using the program downloaded from here: http://members.cox.net/seanwitte. There are directions in the readme file. You will need the C header and source files, pc_interface.h and pc_interface.c, that are in the zip file.
Extract all of the files onto your PC and run setup.exe to install it. You can uninstall the software using the windows add/remove programs function.
Add the C source files to your project and include pc_interface.h in user_routines.c. During the initialization make a call to InitializePCInterface() to set up the data packets. Each time through the program loop make a call to SendReceivePCData(). You can put it right before putdata().
It will let you send back 8 bytes (aliases fb_pwm01 through fb_pwm08), 6 signed integers (sensor1 through sensor6) and 16 bits (fb_sw01 through fb_sw08 and fb_sw10 through fb_sw18). You can log and plot up to ten of the values at once. Once you have a plot you can save the data as a .csv file or a bitmap. The bitmaps are huge, but its the only option I had easily available at the time. The x-axis on the plots is the time in milliseconds.
If you're using a positioning system you can display your location in a 20' by 20' workspace by setting the following values in your program:
current location X coordinate = fb_pwm07
current location Y coordinate = fb_pwm08
heading (in degrees, 0 - 359) = sensor1
The red point in the workspace is sent to the RC as (pc_p4_x, pc_p4_y). We used it to debug our positioning system on the EDU robot.
Unread 25-02-2004, 10:49
Nice work!
Unread 25-02-2004, 10:53
Sean,
Can you create a new thread about this, so that people who don't read this thread can still benefit from it.
A robot Audio System punarhero Technical Discussion 9 02-02-2004 19:19
Righting a robot... archiver 2001 2 24-06-2002 00:26
Are you willing to let others take picture of your robot? Ken Leung Robot Showcase 21 10-04-2002 22:50
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
