Go to Post "How do we make our team be like your team?" That's the sort of question everyone should be asking of these so-called "elite" or "powerhouse" teams. - sanddrag [more]
Unread 25-02-2004, 10:07
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Exclamation Using a switch to control a PWM
I do know C but i am not directly involved with programming, so i apologize if i don't know some obvious things. We are trying to have two switches move a servo (PWM controlled) between two different values. I assumed this would be as simple as checking the status of the button every iteration of the loop and then assigning a certain value to the PWM via an if statement.
if(p1_sw_some_switch == 1){
pwmxxx=some_value
if(p1_sw_some_other_switch == 1) {
pwmxxx=some_other_value
This appears to not be working (ie buttons do not move the servo at all, do the servo does appear to twitch when the OI or the RC is turned on) so my first thought was that maybe the switch takes values other than 0 and 1 like maybe 0 and 255, etc. Any help would be much appreciated
Team 1257
Unread 25-02-2004, 10:39
Re: Using a switch to control a PWM
your code is correct, do you have the backup battery installed?
You may want to do something for you other conditions, though, such as if neither button is pressed or if both buttons are pressed.
Unread 25-02-2004, 10:42
pwmxxx=some_value
You have the general idea, however, the joystick buttons have a value of "0" by default, and switch to "1" when pressed. You may be confusing your test by having the later switch override the first switch test.
Try a simpler test like:
if (p2_sw_trig)
pwmxxx = 254;
else
pwmxxx = 0;
The 7.2v backup battery powers the PWM center pin.
[edit] Joe Ross beat me to an answer. Hey, Ken W. my typing must be slowing down!
[edit 2] deltacoder corrected my reversal of the joystick button values. (I also get left and right confused). Thanks delta!
Unread 25-02-2004, 10:52
Fold em oval!
if (p2_sw_trig)
pwmxxx = 254;
else
pwmxxx = 0;
The problem with that is that this is for a transmission shifter so i want one button press to leave the transmission in a certain gear. But yeah, i should defenitley put initialization values and tell drivers not to press both buttons simultaneously. That servo will go nuts...
Team 1257
Unread 25-02-2004, 11:05
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
If the servo is "twitching" just on the startup of the code then you are okay.
This is just the servo going to it's initial position.
If the Servo is always twitching it might be a low backup battery.
For a transmission shifter you are best to have it on one switch.
0=low gear, 1=high gear
Also, make sure to stop the motorfor a few loops before shifting, and start the motors back up (to selected speed) after th3e servo has had a chance to move.
The psuedocode would look like this
// Motor speed 160 In Low Gear
Shift button changed  // have static store last value
Store Motor Speed     // in static for later use
Stop Motor               // 127, neutral
Move Servo    // 0-254 or 254-0
  count loops for 10 (.2 secs, servo moves full throw in .11)
Start Motor
// Shift on the fly, You got to love it
Setup #defines to track the various points in the shift and switch/case through the shift process.
Hope this helps.
Phil
Unread 25-02-2004, 11:28
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
You have the general idea, however, the joystick buttons have a value of "1" by default, and switch to "0" when pressed. You may be confusing your test by having the later switch override the first switch test.
if (p2_sw_trig)
pwmxxx = 254;
else
pwmxxx = 0;
0 does not evaluate to true - it is the only integer that evaluates to false. the joystick buttons have a value of 0 by default, not 1.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 25-02-2004, 11:32
Fold em oval!
Exclamation Re: Using a switch to control a PWM
Start Motor
Hope this helps.
Phil
That would be ideal, except im not sure that the motors will be still and if they are moving, even if they are being backdrive, it isnt a good idea to shift. I'm afraid if you put something in like this then someone may try to shift while the robot is being pushed or maybe it will keep rolling for longer than expected, etc. Ideally, you could have the shifter only work if an encoder reports no rotation, but we dont have time for an encoder, so i think we will rely on drivers watching the robot and being smart about shifting. (kinda like not shifting without pressing the clutch...)
Team 1257
Unread 25-02-2004, 12:14
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
scottm87 is on a distinguished road
I haven't used the servos w/ the new control system, but when I have worked with servo's in the past, twitching can also be caused by pushing the servo out of the position you are trying to set it to. The internals of the servo have a potentiometer and simple control circuitry to move the servo to a cooresponding value based on the pot. If you try to move it out of the position, it will try to move back.
Unread 25-02-2004, 17:13
Fold em oval!
After trying countless things, we still cannot get it to work. We have the latest default and Master code. We have even tried reading the values of the relays assigned the values of the switches we want to use. We just cannot seem to set a value to a PWM on a button press.
Team 1257
Unread 25-02-2004, 17:15
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Does it work with a Victor?
Unread 25-02-2004, 17:16
Fold em oval!
wow, i feel really really dumb, its because we were setting something to 255 not 254, isnt it?
Team 1257
Unread 25-02-2004, 17:20
AKA: Jamie Bliss
That might be it. Don't worry, I would probably make that mistake if I actually had an oportunity...
Some EDURobotics Problems squide Robotics Education and Curriculum 9 20-01-2004 10:27
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
switch speed control wayne 05 Programming 6 01-10-2003 09:35
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
