#12
Just a heads up... You cant use the gyro from last years kit (very clear... see the QA id's #341, 346, 190). Therefore, you have to use a different one under the custom electronics pricing. The only real viable option is the ADXRS series from Analog Devices, and if you need more then 150 deg/sec, then it will get much harder (the Evaluation Board version of the 300 deg/sec model is just barely over the price limit... you will need to mount 300 deg/sec yourself). Nobody made it very clear in the previous posts, and I didnt know what gyro you were using to begin with.
| Anyone know where to buy a spare yaw rate sensor? | Jim Meyer | Technical Discussion | 11 | 30-03-2003 21:18 |
| Yaw rate sensor pin-out | GregT | Electrical | 8 | 18-02-2003 00:07 |
| Yaw Rate Sensor to 90 degrees? | Bruce C. | Programming | 4 | 11-02-2003 00:36 |
| yaw sensor | CHSguard72 | Electrical | 1 | 06-02-2003 01:44 |
| Yaw Rate Sensor | ImmacGirl_03 | Technical Discussion | 2 | 10-12-2001 15:15 |
