Go to Post We treat productive freshmen the same way as everyone else. As for excesively ambitous new people, we have one rule:what happens in the hotel, stays in the hotel... ;) - Crop-Circles [more]
Unread 25-02-2004, 11:56
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
charging backup battery
We did not get/cannot find our backup batter charger so i was wondering how to go about charging it. For now, we can use 5 AA batteries, but we obviously need a way to charge it. Will any 7.2V DC source limited to a reasonable current ( <2 amps) do the trick?
Team 1257
Unread 25-02-2004, 12:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: charging backup battery
I think chargers are a little bit different than just giving it some juice from something like a power supply. But I could be wrong. You should be able to find a charger at your local hobby store since nearly all RC cars and some RC planes use 7.2V batteries. You will most likely have to switch the plug on the charger or make an adapter or something. If you have a little time, you may check www.towerhobbies.com for chargers or by a replacement charger from Innovation FIRST
Unread 25-02-2004, 13:47
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
We are using
1. The delivered charger with hte EduBot.
2. A PF12 (Park-Flyer) charger from Hobby People. www.hobbypeople.net
search for chargers.
The PF12 is a great charger as all you need to do is dial in the amperage you want and press a button.
The Edubot batteries are 800mah. You set the PF12 to 2c or 1600mah and when the battery is "full", the unit switches to a trickle charge. (1/10 dial setting)
You will need Adapters for the Battery packs (r/c cars use something similar.)
Good Luck.
Phil
Unread 11-03-2004, 17:11
KevnMajikskech KevnMajikskech is offline
Battery Guru
AKA: The Sketch
#0019 (Big Red Robotics)
KevnMajikskech has a little shameless behaviour in the past
Send a message via AIM to KevnMajikskech
u could use a jurryrigged charger but i wouldnt recomend it; it shortens battery life, can overheat batteries, spill acid (depending on batt. type) or it could just catch on fire; use a comercial charger like a rc car charger
Unread 12-03-2004, 00:13
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
I believe RadioShack sells the chargers because the connectors for their RC cars are either similar or identical.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 12-03-2004, 10:18
The connectors are not the same.
Unread 12-03-2004, 10:24
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
http://www.innovationfirst.com/FIRST...electrical.htm
Theres the offical charger, the 2nd thing down for $24.
-Michael Dessingue
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
