Go to Post See, building a really great robot is just a pseudo challenge for the concept of the whole FIRST program. It is just a phony way to bring people together to reach one common goal. - sanddrag [more]
Unread 25-02-2004, 02:25
Joel J's Avatar
Joel J Joel J is offline
do you..
Wiring "3-pin" Shaft Encoder.
Hey everyone. We ordered a few of these shaft encoders from http://www.newark.com and are having a heck of a time trying to figure out how they should be properly wired. Does anyone have suggestions or experience with this unusual encoder?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 25-02-2004, 03:01
Re: Wiring "3-pin" Shaft Encoder.
Did you purchase the quadrature version rather than the BCD or Gray code versions?
It looks like it's a quadrature encoder with the quad signals on A & B, power on C. I'll have to verify with another electrician in the morning to see if he's had personal experience with this model before.
Unread 25-02-2004, 03:07
Joel J's Avatar
do you..
Yes. Thats how it is supposed to be setup. How do we go about porting that to the digital inputs? Should there be a ground connection somewhere? We connected A to the signal of one digital input and B to the signal of another digital input and C to the +5v on the digital input. We are getting a constant 1 as the input of the encoders no matter how many times the wheels rotate (it does not go through each state). I conclude that this is happening as a result of the pin pulling itself to high (since thats how IFI set things up), because its not getting any input, which hints at an improperly wired system. Is this the case?
Joel Johnson
Unread 25-02-2004, 03:18
Yes, I also believe it's the IFI pull-up that's defeating you. It's high when the circuit is open and high when it's closed by the encoder.
You should be able to connect A/B to signal as you are doing and C to ground. Then the digital input will be high when there is no circuit and low when signal is passed through the encoder to ground.
Unread 25-02-2004, 03:30
Joel J's Avatar
do you..
Aha! I switched the C connector from the +5v pin to the ground pin, as you suggested, and it works properly now. Thanks.
Joel Johnson
Unread 25-02-2004, 03:31
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Actually the pull-ups are internal to the PIC. You can disable them using a register.
But yeah, try connecting C to ground. It should work then.
[Edit] Hm.. looks like I'm a bit too slow.
Unread 25-02-2004, 12:55
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Well, yes and no. The 18F8520 does have programmable weak pull-ups, but only on port b, which is mapped to digital I/O pins 1-6 on the FRC-RC and interrupts 1-6 on the EDU-RC. IFI has also included 100K pull-ups on most, if not all, I/O pins.
-Kevin
Kevin Watson
http://kevin.org
Unread 27-02-2004, 17:21
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
That encoder advertises a life of 100,000 cycles. I think it is designed to be an electronic knob, and connecting it to a spinning shaft might rack up the cycles pretty fast.
On the other hand, it doesn't have to work for ten years.
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
