Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 25-02-2004, 13:01
BobcatProgramer BobcatProgramer is offline
AKA: Brian
FRC #0758 (Roboticats)
BobcatProgramer is an unknown quantity at this point
Send a message via MSN to BobcatProgramer
Question Button Programing
I have a relay programed to a button but now I want it to be a press to be forward and then press again to reverse. For example, I am using a selanoid and i want to press the button to have the cylinder go out then the next time i press it the cylinder go in. I can do this easilly in p-basic but I have tried to do it in C and I can't get it to work right. Could anyone give me a hand with this by posting code. It would be appreciated. Thanks
Unread 25-02-2004, 13:14
Re: Button Programing
Put something this in your user_routine, substituting appropriately for switch_value and relay_fwd/rev:
static char relay_state = 0; /* 0 means forward, 1 means reverse */
static char last_switch_value = 1; /* will remember the last state of the switch */
if ((last_switch_value == 0) && (switch_value == 1))
    // here is where you toggle the relay state
    relay_state = 1-relay_state;
    if (relay_state == 0)
        relay_fwd = 1;
        relay_rev = 0;
    else
        relay_fwd = 0;
        relay_rev = 1;
last_switch_value = switch_value;
Unread 25-02-2004, 15:53
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
        relay_fwd = 1;
        relay_rev = 0;
    else
        relay_fwd = 0;
        relay_rev = 1;
Can't you do:
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
if (OI_Switch)
 relay1_fwd = !relay1_fwd;
 relay1_rev = !relay1_rev;
Just be sure to only do it again after a certain time. 26.2 ms is still fast, 38 hz fast.
Unread 25-02-2004, 16:01
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by Astronouth7303
Can't you do:
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
if (OI_Switch)
Clever. That would work. Just make sure to have the variables static.
Unread 25-02-2004, 16:37
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
We coded buttons/triggers to only activate on release, that helps control the longggggggggg button push
Phil
Unread 25-02-2004, 16:43
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
I would do this so your relays dont pulse 40x a second I don't know whose code I just added to tho... sorry
int flag=0;
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
if (OI_Switch && !flag)
flag=1;
if (!OI_Switch)
flag=0;
AKA: Jamie Bliss
Double clever!
[edit]
My code (With suggestion):
//Init Relays
relay1_fwd = 1;
relay1_rev = 0;
static char SwitchVals = 0;
if (OI_Switch)
 SwitchVals = 1;
if (!OI_Switch & SwitchVals)
 SwitchVals = 0;
Of course, you still have to integrate it.
pnumatic programing jacob_dilles Programming 8 24-02-2004 21:49
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Who is doing the programing for team 61 Walter_Jr Programming 5 25-01-2003 00:31
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
Programing of controller DLyons Robotics Education and Curriculum 2 02-12-2002 00:16
