Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 24-02-2004, 11:54
Car Nack Car Nack is offline
Car Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond reputeCar Nack has a reputation beyond repute
Car Nack predicts #3
Car Nack predicts
If FIRST does not establish a system to declare the starting position of
the robots before taking the field, there will be more jockeying for
starting positions than last year!
Car Nack has spoken
Unread 25-02-2004, 14:08
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Car Nack predicts #3
Was there a lot of jockying last year? To be honest, I didn't go to the Championships, so perhaps that was where there was more of this.
I agree with Car Nack in that this year, who goes against whom could be a major contributing factor to who "wins" autonomous.
I keep using the "paper, scissor, rock" analogy, but I think it applies. I think there will be a lot of situations this year were Alliance A can almost always beat Alliance B, Alliance B can almost always beat Alliance C, and Alliance C can almost always beat Alliance A.
If you think about it, this same situation may apply in terms of two robots going for the bonus balls during autonomous mode.
Alliances may have their entire season on the line as to whether or not they can match up with opponent A or opponent B from the other alliance.
It could get heated!
Good call Car Nack.
Joe J.
Unread 03-03-2004, 09:24
AKA: Dr. Joe
FRC #0088 (TJ2)
Car Nack has an Impact...
Looks to me like Car Nack's Prediction #3 has got some folks to thinking in Manchester:
Elimination Matches:
In Elimination Matches a slightly different system will be used. In odd numbered matches (1, 3) the lower ranked alliance (in this example they are the # 8 alliance) must declare first which robot will start on the left and right. This placement can NOT be changed once declared under any circumstance. The higher ranked (in this example they are the # 1 alliance) will get to choose which of their two robots in that match will start on the left or right side AFTER they have seen (or been notified) what starting positions the other alliance has declared. In the even numbered matches (2, and 4 if there is a need for a 4th match) the order is reversed and the higher ranked alliance must declare first while the lower ranked alliance
gets to choose their starting positions second.
Thanks to Car Nack for getting FIRST to address one potential source of confusion at the competitions...
Joe J.
Car Nack Predicts #2 Car Nack Car Nack's Corner 1 06-02-2004 12:48
Car Nack Predicts Car Nack Car Nack's Corner 0 14-01-2004 10:57
Car Nack Predicts archiver 2001 13 24-06-2002 00:12
Car Nack Predicts archiver 2000 2 23-06-2002 21:59
Car Nack Predicts Bill Beatty Off-Season Events 4 11-11-2001 12:12
