Go to Post The Tesla came in the blue tote. This is why you should always inventory your KOP before the replacement window closes! :p - sparrowkc [more]
View Poll Results: What kind of autonomous mode are you using to use?
IR 3 15.00%
Line following 1 5.00%
Shaft Encoders 6 30.00%
Other dead reckoning or sensing (Compass, accelometers, sonic ranging , etc ) 4 20.00%
Hard coding or no sensors 5 25.00%
Other (post) 1 5.00%
None 0 0%
Voters: 20. You may not vote on this poll
Unread 25-02-2004, 16:37
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Autonomous Method
What kind of autonomous mode are you using/hopping to use?
Unread 25-02-2004, 16:42
AKA: Jamie Bliss
Re: Autonomous Method
I'm hard coding with arrays. [And all based on the theoretical free speed and math! Heads up: We're going to Cleveland, OH...]
Unread 25-02-2004, 16:53
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Voted for Line follow but....
We currently have
Mode 1 - Line Follow.
Mode 2 - Dead Recon
Mode 3 - IR Sensor (in works as backup)
Unread 25-02-2004, 17:14
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
In theory we will be able to drive through any series of waypoints the strategy team comes up with. We shamelessly copied team 111. The waypoints are plotted on a map of the field that doubles as a realtime display using data sucked out of the dashboard port. We'll string together a set of building-block commands into a macro for each behavior. Position is determined using a gyro (ADXRS150) and wheel encoder (128 cpr ~ 0.3" resolution). The commands are:
1) Turn to a specific global heading
2) Drive to a waypoint
3) Move the arm to a specific position
4) Actuate a piston
5) Switch gears
Command 3 does not block commands 1 or 2 so it can be running in parallel. It all worked on the edubot but hasn't been tested completely (ok, at all) on the full size robot.
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Autonomous Program Names Venkatesh Programming 12 17-02-2004 10:25
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
