Go to Post Being a good engineer isn't all about engineering. It's about being able to use engineering for a practical application, and to successfully communicate your research or development results to people who aren't engineers - Jon Stratis [more]
Unread 25-02-2004, 23:05
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: The LocTite Monster
Unread 25-02-2004, 23:06
Umm Errr...
Re: pic: The LocTite Monster
I find it hard to believe tat LocTite did that. Did it really? It looks more like it got hit really hard w/something.
1139 Alumni
Unread 25-02-2004, 23:13
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Please Search.
http://www.chiefdelphi.com/forums/sh...ad.php?t=26006
Unread 25-02-2004, 23:15
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I'm just wondering why you chose to use loctite on the speed controllers? Their really doesn't seem to be a need for them if you use self-tappring screws, or bolts with a lock-nut on them.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 28-02-2004, 14:19
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
They were screwed through thin lexan, so we need back nuts. We had no aircraft nuts at the time, so norma nuts with locktite was the answer. The amout of loctite used was indeed excessive, but still, the results were just not what we expected.
It is now history.....but a lesson we will NOT soon forget!
-Quentin
Live free or die....
Unread 28-02-2004, 14:22
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
The same thing I believe happened to us when we used lexan and loctite. The stuff just cracked at the holes.
Unread 28-02-2004, 15:15
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
If you find you need to LocTite screws or bolts into plastics or there's a chance the LocTite can come into contact with plastics (remember it doesn't take much to react with certain plastics) it's best to wrap teflon tape on the threads. You don't need a lot either, one wrap will do. This will prevent the fastners from vibrating loose and still allow them to be removed if neccesary. If you have access to the back side of the screw or bolt you could use a nut with a nylon insert.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 28-02-2004, 15:30
personally I would not use locktite on any electronics - there is too great a chance that you will have to replace them between matches - they are all susceptable to failure from a number of causes - and when you need to swap them out, you need to be able to do it quickly.
if anything, put double nuts on and torque them into each other. You really cant tighten down the screws on the electronics or the plastic cases will crush.
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
