Go to Post Finally!!! I love hugs. - Eugenia Gabrielov [more]
Unread 25-02-2004, 21:46
ThetaDot's Avatar
ThetaDot ThetaDot is offline
here come the warm jets
#1481
Team Role: Animator
ThetaDot can only hope to improve
Advice on drilling through hardened steel?
anybody?
We're afraid we will burn out our drills / ruin bits.
We have to lose weight!!
Unread 25-02-2004, 21:56
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Advice on drilling through hardened steel?
i would do it on a drill press or bridgeport and depending on the hardness i recomend a Carbide tiped drill and it shouldnt have a problem good luck on makeing weight
Unread 25-02-2004, 21:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Are you using large or small bits? crank the speed way down for a large one (This applies for any sort of drilling, regardless of material) Use tons of coolant, and try to use bits that arent pieces of junk. I think Titanium oxide (Nitride? I know it's titanium something) coated drill bits last much longer and drill better than regular bits. make sure you dont go so slow that you're just letting material get packed into the bit, as you'll dull it quickly, but make sure you arent drilling so fast that it dulls the bit, or snaps it.
Cory
[edit] Dont try to drill any large diameter holes with a hand drill. If the bit gets caught, you could jerk your arm pretty badly, and it sure wouldnt feel good for a few days.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-02-2004, 22:05
ThetaDot's Avatar
#1481
Team Role: Animator
Yeah we just ripped them off and currently have the drill presses going.
Thanks though.
Quick response time.
Unread 26-02-2004, 01:03
Umm Errr...
Thanks though.
Just how hardened? We tried drilling through rh68(i think) shafts and ended up going through quite a few bits and shattering a shaft before giving up on that one. We attemptign to use ordinary black home depot stule bits. I have been told that even with carbide drill bits, alot of hardened can be rather difficult and you are really supposed to use some sort of grinder i think. Just curious. Where do you have large amounts of hardened steel on your robot?
1139 Alumni
Unread 26-02-2004, 01:32
Umm Errr...
[quote=Cory]I think Titanium oxide (Nitride? I know it's titanium something) coated drill bits last QUOTE]
There are actually 3 types of titanium coatings:
titanium nitride (TiN)
titanium carbonitride (TiCN)
Aluminum titanium nitride (AlTiN)
The only one you will likely ever see in your local hardware store is TiN. It is easily identified by its goldish color. TiCN is sometimes found on higher end stuff, and AlCn is still somewhat new from what i understand.
1139 Alumni
Unread 26-02-2004, 01:39
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
I would use some oil and use a high quality bit. Go thru with a small bit at a high rmp (like 900 for a 1/4") and then go thru with a larger one (like 400 for 1") Just keep ur balls and u'll be fine.
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 26-02-2004, 08:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
do you need all the strength that comes with the hardness? I mean. if you don't actually need the extra strength, then just hit it with a torch until it's cherry red, hold it there for a few minutes, and then let it air cool. That should kill the heat treatment of most steels unless it's one of the air quenching varieties.
Unread 26-02-2004, 08:19
IndyStef IndyStef is offline
#1018 (NASA & Pike HS Science and Engineering)
IndyStef is an unknown quantity at this point
Dependes on how hard hard is.
Properly hardened high carbon streel, like tool steel for punches and dies - forget it, you won't even sratch it with a regular HSS bit, no matter what coating. And hard metal bits, or carbide bits won't help you much, either.
Surface hardened by carbonizing, or induction treated - with a hard metal tipped bit, or carbide, you might be lucky. Once you are through the surface, things get better.
Tempered steel - depends on the treatment it got, but generally coated HSS or carbide will do the trick - just a lot slower than on Al or mild steel.
Unfortunately, the use of the word 'hardened' is a bit blury in the English language - so you might just talk about a high tensile alloy, or a tough stainless steel. In that case: coolant is the answer. Increases the life of your drill bit a lot. Also - drill presses are not used in the same way as hole punches! Apply force, but not so much that the machine twists and bends. And keep the bits sharp by re-grinding them.
Hope that helps ... some rambling of a German toolmaker and mech. eng. .....
Stef
Unread 26-02-2004, 08:29
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
are yuor drive shafts out of hardened steel?
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 28-02-2004, 05:18
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
It's all about the carbide drill bits. To do the drilling correctly you first must figure out exactly what you are drilling. Then you look in your machinists handbook(noshop is complete without one) for speeds and feeds. Then use a milling machine or high quality drill press. Use flood coolant. The coolant type is important for a good finish and keeping the drill bit cool. You can also find what type of coolant to use in your machinists handbook. If your bit heats up then it loses it hardness which makes it dull extremely quickly. Drilling is a battle of hardness and sharpness the hardest and the sharpest wins. You want the drill bit to win . You can purchase carbide drill bits at Enco or from MSC industrial supply co.
The moral of the story try and put hole in hardened steel before it's hard the harden it. Because there is no way to BS machining hardened steel.
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Dirty Birds need advice DirtyBird213 General Forum 13 11-12-2003 21:24
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
steel plate ........legal dimensions? archiver 2001 1 24-06-2002 00:32
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
