Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 25-02-2004, 23:29
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: What did your robot sacrifice for First Frenzy?
Everyone on our team is worried about our seemingly high center of gravity. It's been a long time since we build a robot with a high center of gravity (not since 2000, but we all know how that worked out..) and we're generally worried about tipping. Theoretically, if our arm is in the closed position during a fall, we should be able to push ourselves back up and keep on driving. We'll see.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We passed on the ball corral system but our arms make for good impromtu ball corrals.
Unread 26-02-2004, 11:18
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Originally Posted by IronSlayTallica
We took a risk and laid out/built our drive train before the kickoff.
If this is what you actually did, you took quite a risk. Check robot section 5.2.5, R09. "Teams must fabricate and/or assemble all custom parts and assembled mechanisms on the robot by the 2004 team after the start of the Kick-off."
Unread 26-02-2004, 11:41
skrussel skrussel is offline
no team (000)
skrussel has a spectacular aura aboutskrussel has a spectacular aura aboutskrussel has a spectacular aura about
Oh my Gosh.........18 pounds!
Unread 26-02-2004, 11:54
edflyerssn007's Avatar
edflyerssn007 edflyerssn007 is offline
AKA: Voice of God
#0329 (The P-Town Pirates)
edflyerssn007 is an unknown quantity at this point
Send a message via AIM to edflyerssn007
Our robot did not sacrifice much of anything, and we can do everything well. It is possible to do many things well if you have the right will to do it. Set a goal, then figure out how to do it, don't just dismiss something because at first it may seem complex. Remember for every complex problem there is a simple, elegant answer that performs exceptionally well.
Team 329: The Raid. If there's an attic, we'll be there.
Where's IQ 92? Doutney
from MIT's Cogshop FAQ: "Robotics requires a very robust background (or, alternatively, a person with just about any background can work in robotics). There are elements of computer science, mechanical engineering, cognitive science, and lots of mathematics in the work that we do. There's also a great deal of "hacking" involved. "Hacking" is the art of taking something apart, breaking it, putting it back together with improvements, and then acting like you knew what you were doing all along."
Unread 26-02-2004, 12:15
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Unhappy Re: What did your robot sacrifice for First Frenzy?
Isn't that against the rules?
Thought you were not to design/build anything prior to kick-off.
If that's the case you will have a hard time moving your implements around the field without a drivetrain.....
Phil
Unread 26-02-2004, 12:27
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Uh, yeah, guys, you can't do that. That's VERY illegal to the nth degree. Unless you said something wrong....
As for Dave Lavery and his KK.... lets go back one year to the 2003 VCU Regional....
Unread 26-02-2004, 14:30
IndyStef IndyStef is offline
#1018 (NASA & Pike HS Science and Engineering)
IndyStef is an unknown quantity at this point
I think it is ok to design something before the kickoff, as long as every part of the bot has been built after it. I even believe that (practically) testing ideas in the off-season is ok - again, as long as none of those parts make it onto to competition bot (unlike the ideas). Otherwise you'd have to empty your brain of any memories from previous year's designs, which is difficult to do.
Sacrifice: We sacrificed hanging and climbing, and instead decided that control of the small balls is cruical. After all, if we manage to steal all the competitor's balls, they can get 100 pts at max. get 11 of those balls into a goal, and cap it - there we go!
Unread 26-02-2004, 14:38
scuba_sm's Avatar
scuba_sm scuba_sm is offline
Deriva-what?
#0862 (Lightning)
Team Role: Student
scuba_sm is on a distinguished road
Send a message via AIM to scuba_sm
Heh... we currently sacrificed.... our drivetrain. We are capable of moving..... in a straight line.... very slowly..... If we try to turn, we get loads of nasty grinding noises as one of our eight chains self destructs.... However, we have a quick fix in mind, and all the parts are ready to go, as soon as we get to a comp, we think we can fix it.... We think. We tried a little more than we have ever done before this year, and it paid off handsomely, except when it comes to our drivetrain. Live and learn, I suppose. See you all at comp!
President 862 Lightning Robotics
My Aresenal for this year:
AK-38 "Lobster"
"Big Daddy Riveter"
Pneumatic grinder
Oh the joys of industrial equipment.....
Unread 26-02-2004, 15:25
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
the only thing we sacrificed is herding balls well the front of our robot will do it but we dont have a specific thing for it. we didnt sacrfice anythign on ground clearance our robot sits lower then any other of our past year robots 1' in of the ground but we can still get up the 6 in step
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 26-02-2004, 20:49
IronSlayTallica IronSlayTallica is offline
IronSlayTallica is an unknown quantity at this point
To clarify...
We didn't actually build it. No metal working was done. No machining, nothing. We thought about it, drew plans, etc. No actual building. Slip of the fingers. Sorry if that came out differently than it really was.
Unread 26-02-2004, 22:04
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
We Sacrified too much time developing and agreeing on a strategy, which, in the end, we weren't able to accomplish due to too much time spent developing and agreeing on a strategy.
sooooo.... due to weight we changed the manipulator designs at the last minute. Our drive system, electronics (with battery), and frame weigh a combined 97 pounds (without skins). Our old manipulator weighed 31 pounds, deweighted, and it was not in complete working order. We COULD have put it on, but it would have been very difficult and time-consuming to remove weight from the rest of the robot.
So we went with something more simple that seems to be good to go, but we didn't get any practice time with it. We do know we can grab and hang, though, and get rid of 2x balls... oh, and we're annoyingly fast and versatile on the field. heh, we find that climbing the 6" platform is significantly easier than taking the stairs.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 26-02-2004, 22:17
Jonathan M.'s Avatar
Jonathan M. Jonathan M. is offline
One Nation Under-Educated
AKA: Spider-Punk
None #0845 (Cutting Edge)
Jonathan M. has a spectacular aura aboutJonathan M. has a spectacular aura about
Send a message via AIM to Jonathan M. Send a message via MSN to Jonathan M.
Well.. At first we decided to sacrifice hanging. However the chasis was still made to be able to climb the platform. We spent the majority of the 6 weeks building and designing the 2x ball handler. In the end, the night before our scrimmage we added the hook that was designed a week prior, and tested the hook out at the scrimmage. So it would turn out that the hook worked better then the 2x ball handler! Since then we replaced our "gripping tongs" with different grippers that work better. So I'm not sured what we sacrificed all together, we can do pracitly everything on the field, but what we do best is hanging. And the one thing we concentrated on the most is 2x ball handler.
- Jon
2005 Florida Regional Finalists with 1251 (Tech-Tigers) and 1270 (Red Dragons)
2005 Florida Regional General Motors Industrial Design Award winners
2005 Pallmeto Judges Award winners
My art site.
My myspace profile.
Unread 02-03-2004, 21:42
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
we sacrificed being able to go up the 6'' platforms.. took off our tread subsystem after we learned it hurt us more than aided us.. we'd rather go with a low drivetrain instead of having something sticking out at risk of flipping.
the second major sacrifice we made was picking up the 2x balls- we can stuff them in and push them out, but can't actually grab them. Instead we focused on the 2x balls' smaller cousin.
Unread 02-03-2004, 23:36
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Originally Posted by OneAngryDaisy
I have noticed a trend this year among robots- many are designed to achieve some aspect of this year's game. As this years game has rather demanding obstacles (steps, bar), the design those teams have are actually a disability in the main battlefield. (Example- huge wheels, drivetrain designed to go up steps, high center of gravity for hanging mechanism/ball picker, all of which can sacrifice speed/torque/center of gravity) I was just wondering what your team sacrificed to achieve your goal in this year's game, and how you plan to overcome that sacrifice..
Well, we decide to pass on manipulation of the 2X balls. (as well as the 10 point balls)
Out main attention is to hanging, and a strong/fast drivetrain.
The idea is to build a solid base deisign for future years. Yes, this is perhaps NOT the srt of game that requires powerful, but THIS was the year for us to do that work.
I hope to see some of you at the Manchester NH BAE Regionals!
-Quentin
Team 4987: Megarams
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
2002 California Robot Games Ken Leung Off-Season Events 11 28-09-2002 22:05
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
