Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 26-02-2004, 20:47
telkanuru's Avatar
telkanuru telkanuru is offline
Generic Carbon Unit
#0246 (Overclocked)
telkanuru is an unknown quantity at this point
Send a message via AIM to telkanuru
Mass properties
Yeah, I know we're all shipped and everything, but does anyone know how do do mass properties in Inventor? I know it can be done (the battery file in the library has an off-center CG), but not how.
"He who has cares also has brandy."
-Gothe
Murphey was an optimist.
Unread 26-02-2004, 21:19
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: Mass properties
The mass properties are automatically calculated based on the geometry and the material. The geometry is obviously determined by you're drawing, and the material is set in the iProperties section(in the File menu). This iProperties menu will then generate center of mass, moment of inertia, mass, volume, etc. The mass and volume are fairly accurate(as accurate as the material data), but I can't attest to the accuracy of the other properties as I’ve never bothered with them.
Unread 26-02-2004, 21:59
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Mass properties
Two things to watch for when doing mass calculations, etc. in Inventor: make sure the material properties are correct and watch out for simplistic models. The battery most likely is modeled as a simple block of whatever material is specified - not as an assembly of lead, gel, plastic case and metal terminals.
Pete Kieselbach
Image Discuss: Mass is bad . . . . CD47-Bot Extra Discussion 2 20-02-2003 19:02
Need help in Mass.? CaptainPlaid General Forum 1 16-12-2002 12:15
Central Mass Kickoff Watching archiver 2000 0 24-06-2002 00:40
Bridge Mass Properties archiver 2001 6 23-06-2002 23:02
FIRST to reach Critical Mass in March, 2002. Joe Johnson General Forum 1 06-01-2002 10:36
