Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Unread 24-02-2004, 23:44
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Operator Interface power ISSUE
Well, our robot is done and driving and we walk out to the field and test it plug it in and start moving the robot via the radio and one of our wonderfully talented and extremely nimble students walk into the power cable ripping the power jack clear for our control panel. Quickly going over the damage we send a person to radioshack to find some parts to replace it. They feel as if they figured everything out about the power and we try it... bad news the robot power light is the only light that is lighting up. Everything works with the tether but thats annoying on a larger playingfield. Any ideas, thoughts, or anything?
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 25-02-2004, 09:49
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: Operator Interface power ISSUE
Perhaps they didn't get a power supply rated high enough for the OI? For some reason I'm thinking that it requires a 1500 mA power supply (and many RadioShack type ones are only like 300 mA). Sounds like it's not getting enough juice.
Unread 25-02-2004, 12:23
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
We ran into a similar problem last year (and the year before) when we kept losing our OI power supplies. One VERY IMPORTANT thing that we found out is that if you get a replacement supply from anywhere other than Innovation First, make sure that it is AT LEAST a 1500mA supply (with 12VDC output, plug tip is positive). While a lower level supply will power the OI, the performance and range of the eWave radio modem will become questionable. The OI will light up, and everything will look like it should be working, but you can't get any signal to the RC (or if you can, the working range may to limited to ten feet or less). This sounds like the same symptoms you are seeing.
You can get a direct replacement unit for the OI power supply from Radio Shack. Part #273-1779, it usually runs about $20. We have tried using lower level (cheaper) supplies before, and every time we had disappointing results.
-dave
Unread 26-02-2004, 01:17
Battle Cattle!
Sorry but there might be a misunderstanding the jack on the OI is what has broken clear from the OI there are no problems with the powersupply. Sorry for the confusion.
Kacz
Unread 26-02-2004, 09:40
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Did you solder it back on? Did you check to make sure that you were providing power and ground in the right polarity?
Unread 26-02-2004, 13:01
Battle Cattle!
Everything seems to be connected properly and we do get a power on light but nothing else. So we are assuming we connected the powersupply correctly otherwise that wouldn't even light up. Is there a something else that could be damaged?
Kacz
Unread 26-02-2004, 13:22
The [replaced] power connector on the OI doesn't work, but it runs okay when tethered, right? You've already damaged the thing, so you probably don't have anything to lose by powering it through the competition port. I think pin 1 is power.
Unread 26-02-2004, 14:27
jjv jjv is offline
jjv is an unknown quantity at this point
...Might be your best bet here, but I'd try and get in touch with IFI, and run your problem by them, and see if you can confirm that it is pin 1
Unread 26-02-2004, 17:28
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
It is pin 1, but building an adapter that powers the OI this way will void your OI warranty. (although we HAVE built such an adapter ... and it works great)
Unread 27-02-2004, 01:20
dlavery's Avatar
Curmudgeon
At this point, the best thing you can do is call Innovation First, get an RMA number, and send it to them for repair. If you are really, really, really nice to them when you call, and explain the situation, they just might send you a replacement immediately while fixing your RC, rather than making you wait until the repairs are completed before returning your original unit.
-dave
Unread 27-02-2004, 07:49
I go along with Dave on return to Innovation First. The power connector solders to the board on both sides. When the connector was ripped out, there was likely damage to one side or the other of the board. Either the board is cracked or there is a broken circuit board trace, and either one requires an expert fix or replacement.
Unread 27-02-2004, 13:46
Battle Cattle!
Sounds wonderful, we shall see what they have to say. Thank you for your replys!
Kacz
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
