Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Unread 26-02-2004, 18:21
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Showing You're Under 10ft/s
How are teams planning to document or show to the judges that their hanging mechanism is <= 10ft/s at any given time?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 26-02-2004, 18:31
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Showing You're Under 10ft/s
if you see the 2004 FRC Inspection Checklist you will see that the speed < 10ft/sec is on there. Thus i am taking it you must pass that point if you plan on hanging prior to competing on friday.
-Michael Dessingue
Unread 26-02-2004, 18:35
if your bot reaches up and grabs the bar in less than 1 second, you are travelling > 10 ft/S
seems pretty straighforward.
Unread 26-02-2004, 18:40
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Nononono, we have an arm that starts at the max distance ~5 ft (its at an angle), so if it reaches up 5 feet and hits the bar in one second thats 5 fps not 10 fps... although we are very close to 10.. i havent really thought about this, it'll be interesting to see what ways you guys have
Unread 26-02-2004, 18:41
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Ken, that's if you're on the floor. The distance from the topmost platform to the bar is only 9'. So from that to the bar would have to be <=0.9s.
Also, I understand that it'd be easy to have a stopwatch on hand in the pits to time the sequence with the inspectors watching, but what about instantaneous velocities? Does FIRST only care about avg velocities? That's what I'm wondering about - because that would be highly frustrating to document [instantaneous].
Unread 26-02-2004, 18:48
If your arm move less than ten feet in 2 seconds you are going to be ok - you can reason out the start and end speeds if you measure the average.
remember the reason behind this rule is safety - its not to hard to observe a device in action and conclude that its going to hurt someone, or that its safe.
Unread 26-02-2004, 19:01
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
I don't think the rule is really meant to be about arms, but about projectiles. I could be wrong
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 27-02-2004, 02:13
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
The rule applies to ANY mechanism that engages the chin-up bar. It doesn't matter if it is an arm, projective, spear, grappling hook, or string of spaghetti.
-dave
Unread 27-02-2004, 04:05
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
-dave
Now what if this bar grabbing device is an elevator, constrained at the bottom and top (with guides so it can only move upward XX feet). Does the 10fps rule apply here too? Another example would be a pneumatic device (using a piston) that extended upward toward the bar, a smaller piston (3/4" bore) definitely can move faster than 10fps, is this devices speed restricted as well?
The way I read it, I have a hard time applying the rule to objects other than projectiles. Using the spirit of the rules, I could imagine why an arm moving faster than 10fps could be dangerous, however, I do not see it being as lethal as something that is released into the air (such as a grappling hook) and could potentially hit spectators/drivers/people. Although there are some exceptions, most 'contstrained' devices pose a lesser risk than some sort of projectile.
Point me in the right direction, this might be problematic to some teams at competition (including ours).
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 27-02-2004, 07:07
Dave already pointed you :c)
the end of any device designed to capture or latch onto the bar cannot move faster than 10 feet per second.
a hook or pole that extends faster than that would be dangerous to anyone standing near it when it goes off - on the field setting up the bot, or working on the machine in the pits, doing a demo for people in the pits, standing in the queue waiting for your match to start...
Unread 27-02-2004, 09:25
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
a hook or pole that extends faster than that....
if your bot reaches up and grabs the bar in less than 1 second....
is the 10 f/s rule only considered with vertical velocity? just trying to clear this in my mind....thx
Unread 27-02-2004, 10:54
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah we have an arm that pivots. Does that mean that if the tip of the arm rotates from near the floor up to the bar in more than 1 second we are OK? Because it travels more than 10 feet.
Unread 27-02-2004, 11:35
Since there seems to be some confusion about the rule, here it is:
<G08> Mechanisms which interact with the Pull-Up Bar are limited to a maximum tip velocity (relative to the ROBOT) of 10 feet per second.
Mechanisms means anything, arm, projectile, etc. And it isn't just the vertical velocity. It is the tip velocity. For example, our arm rotates approximately 180 degrees with a 5 foot radius. It takes just over 3 seconds to do that. So, our average velocity is just over 5 ft/sec. I am hoping that is enough margin that we won't have to "prove" the speed. If you calculate that you are closer to 10ft/sec then you should be prepared to prove the speed, such as in
<R82> During inspection, teams must be able to demonstrate the operation of any robot mechanism intended to interact with the Pull-up Bar on the center structure on the field, and show that its tip velocity complies with the 10 feet/ second velocity maximum limit requirement. One way that this may be accomplished is by recording the tips motion with a camcorder with a known frame rate (to provide delta time) against a measuring tape background reference (to provide delta distance).
Yan, use common sense with the average vs instantaneous measurments. If one part of your movement is much much faster then the rest, you should be prepared to show that in that part it isn't more then 10 ft/sec. However, if by your eye you can see that it has a fairly constant speed, then average speed would be perfectly acceptable.
Of course, I am not the official answer. If you really have concerns about your method of documentation, then ask on the FIRST Q/A.
Unread 27-02-2004, 14:39
Engineering Mentor
FRC #0254
Hmm... I do remember reading that and worrying... I guess I overlooked our individual circumstance. It is easily fixable, so no problems.
Thanks for the help.
-Travis Covington
Envioments for showing off objects MConte05 3D Animation and Competition 4 18-01-2004 01:00
Thank you Andy Baker Thanks and/or Congrats 9 14-05-2003 18:21
No Who am I picture showing up in message on left hand side Elgin Clock CD Forum Support 5 16-10-2002 12:09
Showing Appreciation archiver 2000 0 24-06-2002 00:30
