Go to Post However, I am a firm believer in the theory that if you are pushing with a mecanum wheeled robot you are doing it wrong. - Andrew Schreiber [more]
Unread 24-02-2004, 22:15
Wbrown0389 Wbrown0389 is offline
None #1284 (DART - Design Applications for Robotics Technology)
Wbrown0389 is an unknown quantity at this point
Send a message via MSN to Wbrown0389
Exclamation Loading Program to Controller.....problems
We have been uploading our program for some time now and it has always worked properly until recently. Now when we add a function to the code, no matter what the fuction is, the code will not upload to the controller. The strange thing is that we can comment out ANY bit of code and recompile and upload the code again, except this time it works. We have already checked the size of the code and the utilization and we are using about 41% of the space, so we have basically ruled out that problem.
Does anyone have any idea what is causing this and how can we fix it??
Thanks
Wes
Team 1284 - DART
Unread 24-02-2004, 22:28
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: Loading Program to Controller.....problems
Thanks
Wes
Team 1284 - DART
Do you have the current IFI loader?(look on IFI's website) The original one had problems over a certain code size.
Unread 26-02-2004, 00:45
danielkitchener's Avatar
danielkitchener danielkitchener is offline
408 Computer Nerd
AKA: Daniel Kitchener
#0408 (Roboticks)
danielkitchener is on a distinguished road
PAth names are limited to 60 characters. Try moving your hex file straight into the C:\ directory and try loading it to there. That could be the problem
Unread 26-02-2004, 07:27
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Say, There is a compile option for large/small space. Would that have to do with this?
Unread 26-02-2004, 17:59
The program sits in the root of C: so we know that isn't the problem. I haven't talked to our programmer in a few days, so I haven't been able to tell him to try and download the new IFI Loader.
Unread 27-02-2004, 17:14
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
We got stuck at some point -- it wouldn't download at all. This got us going again:
http://www.innovationfirst.com/first...Action=Q&ID=73
Which says, in part:
"To force your 2004 EDU RC into Wait-for-Download Mode (PROGRAM STATE orange) you can hold down the PROG button while turning it on. You must release the ON/OFF button before releasing the PROG button."
Possible Robot controller problems mpalermo81 Technical Discussion 1 24-02-2004 22:43
RC program state problems Max Lobovsky Programming 3 14-02-2004 15:02
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
