Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 27-02-2004, 12:11
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: anti-gravity-gas
Originally Posted by generalbrando
Also, get creative! Go on down to Home Depot or Lowes or Menards for you Midwesterners. Look around and see what they have for you to play with. You'll find strong aluminum tubes that are very light and relatively cheap.
We didn't use any this year, but I've found the best stiff lightweight structural material if you don't need the strength is 6 ft. shower curtain rod that Home Depot carries - it's 1 inch diameter by about .015 thick if I recall. Makes really nice long mechanisms - you don't get the droop of PVC.
Unread 27-02-2004, 12:17
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
when you're done drilling holes in the air tanks, and you're still over, make sure you take that proton-heavy lead out of your battery.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 27-02-2004, 17:28
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Originally Posted by ToMMan b182
well our personal preference is hydrogen, but sometimes that can get rowdy.....
naa im just kidding. all you need to do is selct materials wisely. EX. if something that you are planning to make of 1/2 lexan can be made with 1/4 aluminum, go for the aluminum. (also see the reference on what is called a mill and thing that goes on mill to make big holes...hey im a programmer, what do you want?)
Take a vacuum pump and suck all the air out of your pneumatic system. No air is lighter than H2.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 27-02-2004, 22:06
Umm Errr...
Originally Posted by Adams High Man
alright, what are all you people injecting into your air tanks to make your robots 130lb? we are bordering on 130lb, and we barely have anything! our arms are fiberglass, our transmissions weigh 2.5lb. Then i see all metal robots with 6 wheels, big huge gear boxes, and 10' long arms. whats the secret?
I often wonder the same thing. Besides the team secrets Andy leaked earlier in the thread, here are a few mostly obvious tips off ghe top of my head.
Not all aluminum frame materials are equal. Pick something that is light. This is an area that can make a big difference. Last year we made our bot out of 1.5 in welded aluminum square and we were overweight. This year our robot is at least 4 times more complex and was undereight. We used 1010 series 8020 extrusion. With square round, etc wall thickness is a big factor.
wheels suck weight There is no need for giamongous metal rimmed go-kart tires. Avoid anything with metal rims like the plague.
resist the hive As goofy as this may sound, wires do take up weight, several pounds of it. Avoid hivelike electrical panels, make things as short and neat as possible.
No need for overly beefy gears. I see alot of gears that look like they belong in a bus transmission. avoid gears with hubs. Use keyways, and spacer tubes. We have gearboxes that we direct drive out of with 12.5 in wheels that combine the chips and the drills. They use 8mm wide module 1 hubless steel metric gears and are plenty beefy. Don't be afraid of plastic gears and sprockets either. Timing belts can pften be lighter than chains.
swiss cheese it early you cna save alot of weight and frusteration if you lighten parts from the start. If there is any unnecessary, non-structural material on a part, remove it.
Stay away from oversized fasteners Fasteners take up alot of weight. Use ones that are the right size. IE: not too long not too wide. In some cases if you are really desperate, you ,ight consider going back and replacing things with plastic equivalants. IE: electrical components.
1139 Alumni
Unread 28-02-2004, 00:34
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Two words....Thinwall Aluminum.
Unread 28-02-2004, 00:40
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Bah, just use the battery that came with the EDU-Bot to run your robot!!! That sucker is so small and light... Alot lighter than than that passe' big battery you get in the kit!!! That battery is like so 5 minutes ago!!!
Unread 28-02-2004, 00:59
telkanuru's Avatar
telkanuru telkanuru is offline
Generic Carbon Unit
#0246 (Overclocked)
telkanuru is an unknown quantity at this point
Send a message via AIM to telkanuru
Remember. Your RC is heavy. More specifically, the chips inside your RC are heavy because they contain data, and data is heavy. Open up the RC and drill a hole through each chip. Also, pneumatic tubing weighs a lot. It too can take many, many holes.
In all seriousness, tho, a charged battery weighs a noticable bit more than an uncharged one. 13.5 and 10 lb, respectively, if I remember right... Dosn't make sense to me, tho... Electrons arn't that heavy. Hell, you don't even know where they are/are going.
"He who has cares also has brandy."
-Gothe
Murphey was an optimist.
Unread 28-02-2004, 02:01
Christina's Avatar Unsung FIRST Hero
Christina Christina is offline
Christina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant futureChristina has a brilliant future
Send a message via AIM to Christina
Well, if you're really having problems with weight you can do what Greg did for our robot. Drive it backwards off a platform over a foot high and put a hole in the side of our compressor. That worked wonders. *shakes head*
~*~Christina Puplava (formerly Alzona)*~*
"It's kind of fun to do the impossible." ~Walt Disney
Unread 28-02-2004, 12:50
Taylor_Ratliff Taylor_Ratliff is offline
College student - mentor
FRC #0704 (SGP Robotics)
Taylor_Ratliff is on a distinguished road
Helium? A vacuum? Why not just use a little engineering
our robot weighs in at 84lbs http://www.chiefdelphi.com/forums/sh...ad.php?t=26186
Unread 28-02-2004, 14:43
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I'm curious, have you actually weighed the same battery charged vs uncharged? Did you get this information from a source (if so, could you point me towards it)?
I'm not doubting you , I'm just trying to figure out what might cause this. Keep in mind that a charged battery has the same number of electrons as a uncharged one.
It is possible to lose quite a bit of weight by drilling holes, removing excess wires, and eliminating redundant fasteners. However, if you need to lose any substantial weight you'll probably need to redesign or eliminate a major component. Look at everything on your robot and ask yourself the question "Does this part add any value to my robot?" If you answer "no", cut that part off. It’s really disappointing to have to cut a major (and working!) subsystem off a robot but its often the only way to make the weight limit.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
gas struts archiver 2000 1 24-06-2002 00:13
New IT info? Mike Soukup Dean Kamen's Inventions 10 08-12-2001 23:03
