Hi everyone !
Well, I have this big issue in my head and I think for the most part I am like overthinking the problem... My actual problem is the understanding of significant figures IN calculations. For example... The correct results WITH the correct sig. figs. for: (angles are in degrees) 1314.459 + 3.01 23.15 * 5.2 29.87777 / 2.0 31.7 * sin(76) pi * 2.3 ( 2.765 + 4.1 ) / ( squrt(3*sin(55))) I think you get the idea... I get confused whenever I start to mix up angles and many digits from different COMBINATIONS of arithmetic operations. I really hope someone could clarify this for me b/c its killing me and it's taking a LOT of points from my exams ![]() Thanks a lot in advance. DEJHAN |
Re: Significant Figures ?
You should round your results to the below expressions to the stated sig figs:
1314.459 + 3.01: 3 sig 23.15 * 5.2: 2 sig 29.87777 / 2.0: 2 sig 31.7 * sin(76): 2 sig pi * 2.3: 2 sig ( 2.765 + 4.1 ) / ( squrt(3*sin(55))): 2 sig If a number is like 0.0001, that's 5 sig fig, but 0001 is 1 sig fig. If it's 2.32340 that's 6 - the 0 at the end counts if it's there. If it's 3.0, it's two, but 3. is also two - the decimal signifies that (though normally no one writes it like that). A number such as a constant like the speed of light is considered to have infinite sig figs. You should do all problems without rounding. Then at the end, round to the # of sig figs of the value in the problem with the least # of sig figs. |
I think for number 4 it would be 3 sig figs since the sin(76) = .970295.....
Thank you but I still have something unclear; since the first calculation would yield a result of: 1317.469
How am I supposed to report that ? As 1317.47 ? Could you please type ALL the results for the calculations I posted so I can see that and also that will help me to figure out things a bit quicker. Thanks a lot ! |
Yeah the addition one are wrong.
Answers: 1. 1317.47 , 6 sig figs 2. 120 , 2 sig figs 3. 1.4 , 2 sig figs 4. 30.8 , 3 sig figs 5. 7.2, 2 sig figs 6. 4.9, 2 sig figs For addition the sig figs are determined by the least amount of decimal places. For multiplication they are determined by term with lowest amount of sig figs. |
Heh, I looked at #1 too fast and thought it was multiplication: "1314.459 + 3.01: 3 sig" For addition and subtraction, you take the least # of digits after the decimal and make sure your answer has that # of sig figs. 1314.459 + 3.01 would equal 1317.47 (rounding to 2 sig figs after decimal). If you had to add 0.000000001 to 1.1, you'd get 1.1. Because the limiting sig fig is from 1.1. |
#7
1314.459 + 3.01=1317.47
23.15 * 5.2 = 120 (2 sig digs) 29.87777 / 2.0 = 15 31.7 * sin(76)=30.3 pi * 2.3=7.2 ( 2.765 + 4.1 ) / ( squrt(3*sin(55)))=3----1 sig dig(the 3 is only one sig dig) for multiplication and division it is the total number of digits in the smallest number for addition it is the highest place value (1200 would be 2 where as 1200.1 would be 5) you do all arithmatic first then either round or truncate to correct digits i am absolutly sure about this, i was the only one in my class (gifted) who could even understand why this is so. |
#8
You actually meant 4 in your last calculation right ? (1 digit) And what would be the result for 23.15 * 5.9 ? Would 137 be correct ? (3 sig figs? -- but look that 5.9 has only 2 sig figs.) Last edited by Dejhan_Tulip : 27-02-2004 at 18:51. |
#9
So it's 140
#10
"23.15 * 5.9 = 140 in sig figs"
That is why I hate sig figs. They are only cause for error in your answer. I have yet to be told by my school's teaching staff what purpose they have or how they are beneficial to our society. |
#11
If anyone wants a super detailed very correct way to understand and count significant figures I will copy it out of my Chemistry book for you. Just let me know.
#12
Oh yeah, and the 3 is understood to be 3.0000000 (infinite zeroes) so there is 2 sig figs on the last one. Last edited by ngreen : 27-02-2004 at 21:25. |
#13
So, if I do the following:
29.87777 / 2.0 = 15 (2 Sig. fig.) and 29.87777 / 2 = 10 ( 1 Sig. fig. ) Is that correct ? |
#14
No, two would be understood as 2.00000000 to infinity so the answer would be 14.93889 to seven sig figs. This at least what my chem book says.
#15
Is that true ?? So, not 1 sig. fig. but 7 !?!? (for the division by 2)
And also, for ( 2.765 + 4.1 ) / ( squrt(3*sin(55))) what is the correct result to the correct number of sig. figs. ?? Thanks a lot for the help so far guys, I am really putting some concepts together in my head Dejhan |
| Optimal Direction of the Drill and Chips | mzitz2k | Motors | 17 | 06-02-2004 16:54 |
| Great job on Sally Forth! | archiver | 2001 | 7 | 24-06-2002 02:29 |
| Rule M14 | archiver | 2000 | 10 | 23-06-2002 22:26 |
| Battlebots Action Figures | Madison | Chit-Chat | 29 | 19-08-2001 20:27 |
