Go to Post Teach 'em young, and they will go far. - Vashts6583 [more]
Unread 22-02-2004, 23:37
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Re: Bouncing turns
Originally Posted by Elgin Clock
Somoene actually suggested using a wax type substance like armor-all on the tires? Would that work, or be legal?
yes, anything to reduce the friction
there is another post about this(by me) but it ended up in the pnuematics section sence i said pnuematic wheels HA!
http://www.chiefdelphi.com/forums/sh...ad.php?t=25061
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 23-02-2004, 11:35
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Bouncing turns
The Schmoebots had this problem as well. They solved it by simply removing the tires on one end and running on the rims. There's a little bit of slip from the different diameters, but it doesn't seem to cause any problems.
Christopher H Husmann, PE
"Who is John Galt?"
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: Bouncing turns
Hmm. Well, I would think wax could be a bad idea, since it could(would?) rub off easily onto the carpet, something which FIRST would not like.
However, what does work, is wrapping some sort of material around the tires...
Unread 23-02-2004, 11:57
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Bouncing turns
we had this exact same problem last year. the cause was too much top weight and too much traction. we looked like we were convulsing while turning. we could never figure out how to stop it and just kind of lived with it. on the bright side...we never lost a pushing match. good luck!
Collin Fultz
Unread 23-02-2004, 14:03
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Bouncing turns
My team, 177, has perrenially had this issue we finally broke down and made omniwheels for the rear. Our experience shows that having lower friction in the rear wheels increases manueverabilty while retaining control compared to the fronts. Most teams who saw our bot at the UTC scrimmage can attest to it's speed and manueverabilty with these wheels. We were also never at a loss for traction.
Unread 23-02-2004, 14:16
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Re: Bouncing turns
No you can not do this, once again a case of "if you don't know don't answer"
<R15> Lubricants may be used only to reduce friction within the robot. Lubricants shall not be allowed to contaminate the playing field surfaces, balls, or other robots.
You can use anything that will stay on your wheels, tape, paint, glue. But nothing that will rub off and contaminate the field.
I Hate Signatures!
Unread 23-02-2004, 14:24
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Bouncing turns
or make a wheel outa lexan or delrin
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 25-02-2004, 15:46
Ruffryders1273's Avatar
Ruffryders1273 Ruffryders1273 is offline
Billy
FRC #0716 (Who'sCTEKS)
Team Role: Operator
Ruffryders1273 is an unknown quantity at this point
Send a message via AIM to Ruffryders1273
Re: Bouncing turns
Originally Posted by Jones571
This was a problem at the UTC scrimmage 716 was bouncing out of control they didn't have the problem as bad after taking most of the air pressure out of there tires.
We did have this problem but after our first match we deflated our tires to the recommended 35psi(instead of 50psi), we still get some bounce but only in low gear.
Billy
Team 716
The Who'sCTEKS
WHATEVER IT WAS, IT WASNT ME!!!
Mistakes serve two purposes: learn from them and redrilling holes/lose weight!
2006 UTC Suffield Scrimmage Champions
2004 UTC Regional Champions
Unread 25-02-2004, 16:07
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Bouncing turns
wax wont rub off. Though you would loose so much traction that you probably wouldnt be able to climb to the bar anymore.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 27-02-2004, 17:51
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: Bouncing turns
I assume everyone is talking about 4-wheel-based bots. I guess if you were surprised that it wouldn't turn well, the lesson is to think carefully before committing to a major design decision.
Our bot has only two wheels, midship, and plastic skids on the corners. It turns nicely in any radius we choose and turns on a dime.
And it can't climb the steps at all. Engineering is the art of making tradeoffs. We'll go for the bar from the side.
Has anyone built a bot with a rear-end differential and steered wheels like a car?
Unread 27-02-2004, 18:05
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Bouncing turns
Be nicer than that. You can use anything that will not rub off on the field. Armor-all when used right won't damage the playing field while making your tires a little slicker. I wouldn't reccomend it though. However tape may not be used. The only tape that is allowed is electrical tape as an electrical insulators. I don't want to be offensive about this but it is not good to post about someone else not knowing the answer and having incorrect statements in your own comments.
Unread 27-02-2004, 19:53
jparkteach's Avatar
jparkteach jparkteach is offline
FRC #2070 (Ridgefield Robotics)
jparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to beholdjparkteach is a splendid one to behold
Send a message via AIM to jparkteach
Re: Bouncing turns
It has been posted elsewhere but our team came up with it early on during the design stage once we realized that we might have some problems turning. Zip-ties on either the front or the rear wheels. On all four wheels is overkill, you may want to put them on the wheels farthest from the center of gravity of your robot in order to keep as much traction as possible.
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Bouncing turns
Tried armor-all like tire shine. It doesn't really help.
Unread 27-02-2004, 20:04
Team311's Avatar
Team311 Team311 is offline
School Is Boring
#0311 (Red Jammers)
Team311 will become famous soon enough
Re: Bouncing turns
we added a caster that helps us turn. it lifts the front two wheels off the ground andit turns much better
Unread 27-02-2004, 22:51
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Re: Bouncing turns
We have struggled with this problem since we started 2 years ago.
Last year, we put zip ties, 1 every half inch or so, on the wheels at the lightest end which helped a lot.
This year, thanks to an idea that we got from Team 254 and Team 60 (which I understand originally came from Team 25), the problem is history.
The solution: 6 wheel drive with the middle wheels 3/16's of a inch lower than the other wheels. We turn on a dime and still have 6 wheel drive using chains. Basically our robot is rocking on the middle two wheels. We had to actually reduce the turning rate to make it more controllable.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Disney turns away visitors on Segways Clark Gilbert Dean Kamen's Inventions 8 19-02-2004 22:07
Image Discuss: 294 Teaser, it turns? CD47-Bot Robot Showcase 3 03-02-2003 16:56
Pneumatic..Schematics..are bouncing everywhere archiver 2000 0 24-06-2002 00:38
Bouncing heads.... archiver 2001 2 24-06-2002 00:14
Competition Name? archiver 2000 11 23-06-2002 22:09
