Go to Post If you let me borrow your time machine, there are various ways to fix this. But mine is on the fritz. - Greg McKaskle [more]
Unread 27-02-2004, 22:03
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 571's new gearz loose weight
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: pic: 571's new gearz loose weight
wow awsome gear box. how does it shift?
"You're not a real programmer until all your sentences end with semicolons;"
Unread 27-02-2004, 22:05
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
question?.... how much does that gearbox weight? it looks nice...
Unread 27-02-2004, 22:14
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
the picture says 12 pounds. thats one heavy sucker, 24 combined
Unread 27-02-2004, 22:24
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
when they are in the bot they have a tiny air cylinder that shifts them i think it is like a 3/4'' by 1 inch stroke
each gear box weighs close enough to call them 6 pounds each in round numbers. they are awesome and designed that no matter what side of the bot they are on that they run forward to get the best performance possible a nice added bonus. Ill look for a pick on how they shift and post it tonight
Unread 27-02-2004, 22:26
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Correct me if I'm wrong, but this looks very similar to the Technokats' 2002-2004 shifting technique. If it is...
This is a shift-on-the-fly system that uses two free-spinning gears (The outer two on the right of this pic) with some sort of mechanism that will engage with that center "dog" (between the two outer gears on the right). This center dog is connected to the shaft so that the shaft cannot spin w/out the dog spinning, and vise-versa. Hi/Lo gear is determined by which gear the dog is engaged in. I hope that this answers your question.
check this out for drawings of and other info on our 2003 gearbox --> http://technokats.org/archive.htm
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
Unread 27-02-2004, 22:37
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
i tryed to upload a picture with the shifter in there but is said it was to big. if you want me to send a pic of it to u i will be glad just email me JcSpyder1211@aol.com and ill send it out to u
Last edited by Jones571 : 27-02-2004 at 22:59. Reason: spelling mistake. big enough to warrant fixing.
Unread 27-02-2004, 23:29
AKA: Ari
i dont blame them... our each transmission weights 15 pounds...
Unread 28-02-2004, 00:43
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
hah! ours weigh almost double that!.....but then again, ours run the length of the bot...
http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=6516&direction =DESC&sort=date&perrow=4&trows=3&quiet=Verbose
I never really appreciated speed holes until after building that bot
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 28-02-2004, 09:16
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
but that is 12 pounds for both of the trani'z not each
y do your trani'z run the length of your bot?
Unread 28-02-2004, 13:12
RogerR's Avatar
AKA: Roger Riquelme
we're using direct-drive (spur gears) instead of chain or pulleys to transfer power from the motors to the wheels of our bot
Unread 28-02-2004, 13:16
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
y do that the weight must be a killer. It really eats up your weight limit quickly? im not seeing the benefit of that.
Unread 28-02-2004, 13:28
RogerR's Avatar
AKA: Roger Riquelme
actually, in the begining, we weighed about 78 lbs, but after some lightening holes in the gears, turning down the hubs, and replacting many steel parts with aluminum, we dropped almost 15 pounds. we didn't want to deal with the loss of effciency and other problems that chain drives can have if they aren't designed properly. we actually modeled our drivetrain after team 25, so we aren't the only ones to do this.
Unread 28-02-2004, 13:30
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
yea i can understand that 25 had an sweet drive train last year i cant watie to see what they did this year.
Unread 28-02-2004, 15:35
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
just for clarification...
yes, it does use the same principles as the Technocat transmission, but follows the design only very loosely.
the two of the gears on the output shaft have had dogs machined into, creating a standard 7/8" (i think) hex head. the engaging mechanism is a relative cheap 7/8" socket wrench attachment, which can slide in between connecting the low gear or the high gear. the shifting is done using a 3/4" ram which shifts both sides at the same time.
Each gear box weighs 6 pounds. The wheel output shaft is connected to a single chain that connects all wheels on a side. On one of the gearboxes, the alternative output shaft runs into another dog engaging mechanism identical to the one that switches the gears itself. activating the piston on that shifter hooks the output of the gearbox to the winch.
I do have pictures of the shifter, i will attach them as soon as i get back on my own computer.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
pic: last minute weight loss CD47-Bot Robot Showcase 11 26-02-2004 19:41
pic: last minute weight loss CD47-Bot Robot Showcase 6 26-02-2004 01:17
pic: Team 1156 - Weight Measure CD47-Bot Robot Showcase 5 25-02-2004 23:50
pic: 571 2004 new gearz.. CD47-Bot Robot Showcase 7 22-02-2004 20:10
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
