Go to Post The only constant in FRC is change. Learning to adapt to change in competition is the best way to prepare for change in real life. - Jessica Boucher [more]
Unread 04-02-2002, 18:44
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Question Autodesk Inventor iPart Factories
So, I'm getting used to Inventor now, and I'm being quite productive with it. I watched the tutorials, and I noticed the iPart that the tutorial insertd into the model.
I thought that would be very useful for our extruded aluminum profile. We could simply specify the distance that we want the aluminum to be extruded.
I'm having trouble with the custom iPart factory. I got the standard iPart factory working, but that limits the piece to distances explicitly written in the iPart table. The help file says you can make a custom iPart factory that can generate parts to any values for the parameters that you would like.
I'm having trouble getting this working, though. Can anyone help? Right now, the model I am using for the profile is simply one sketch extruded distance "Length" and that is the key being used in the custom iPart factory.
Thanks!
Unread 02-03-2002, 22:36
Jan Olligs's Avatar
Jan Olligs Jan Olligs is offline
#0448 (Crandroids)
Jan Olligs is on a distinguished road
I don't quite know what you mean, but if you want to say that the part does not change when you click "Done" in the table, you might want to try clicking "Update" on the tool bar in the main window.
I have great faith in fools - my friends call it self-confidence. --- Edgar Allen Poe
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
FIRST Blast: 2004 Autodesk Software Information! miketwalker FIRST E-Mail Blast Archive 1 03-11-2003 21:21
Autodesk hath taken pity on us... RachelOfMars 3D Animation and Competition 2 05-04-2003 11:12
